Insignia lcdtv32 poewr on but no picture
Power led turns blue when turned on but no picture still black...checked all caps there fine ....theres two different boards to this tv,,brown board and green i have the green..... I have the same problem with a 27 inch Insignia NS-27LCD
Turned it on one day last week and no picture no sound.
Screen is black.
The only thing that happens is the power LED changes to blue
when its turned on and red when its off.
I checked the fuse and its good.
I unpluged it for a day and nothing changed .
The TV is only a year and a half old .
Thanks for any assistance
  • B-rock32 Apr 30, 2009
    my tv does the exact thing just wondering if anyone was having the same problem or what you did to resolve it. any help would be appreciated please!!!
    President:
  • 1,779 Answers
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
Posted on Feb 26, 2009
Insignia tv no picture and sound until it warms up
it only takes one bad or slightly bad cap to cause this, back a bit, caps that have a problem will begin to regain some capacitance after they get hot------does this sound familiar?
just id the cap and replace it and look for any others even slightly puffy.
Sep 02, 2012 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 Intermit picture and sound
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Some TV is very prone to bad solder.
Feb 27, 2008 | Insignia IS-LCDTV32 32 in. Television
When tv turned on it only has gray , black and white bars.
Sounds like burst caps in the power supply. If that is the case, replacing the vented caps (burst tops) should restore the set to normal operation.
Jul 06, 2010 | Insignia IS-LCDTV32 32 in. Television
Ns 32 lcd on/off continuously no picture speakers click when it turns on
Power supply module will be the first palce to check, look for 5vdc, 12vdc, and 24vdc. Look for bad caps with bulging tops also.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Insignia+IS-LCDTV32+
Jan 06, 2010 | Insignia IS-LCDTV32 32 in. Television
No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Apr 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Insgnia LCD NSLCD26A
After turning on my television it black screens. I can just barely make out the snow screen and the menu but I can't see it enough to adjust the settings. Can I reset my television back to factory specs?
Aug 07, 2008 | Insignia IS-LCDTV32 32 in. Television
No sound
I would be naturally curious of the no sound symptom but the no blue light makes this puzzle even more of a challenge.
This unit has some VERY poor power supplies in them, in particular three caps E919,E920 & E921 (680uf/35v) usually fail causing a complete dead condition. But there are also a total of 16 caps in various areas of the supply handling low voltage sources for various other areas of the TV and it would be my suspicion that one or more of those has failed and you might not be too far from a complete failure of the supply when the main three 680uf caps finally short. At least I'd start there...
One other thing has me suspecting the supply. Both the blue light and the audio circuit depend of the +12v source. It's the first area of the supply I'd begin with in a trace.
Hope this helps.
Bill
Apr 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Please help
http://www.fixya.com/support/t123763-tv_hard_time_turning
check out this posting on fix ya, i just fixed my tv this morning.
Oct 29, 2007 | Insignia IS-LCDTV32 32 in. Television
No Picture, Power LED goes from Blue to Red
It sounds like the red LED is signifying a fault. Check your manual (or ring the manufacturer's support line) to find out what the red LED means. If it does in fact signify a fault, file a fault with the manufacturer and return it to them under warranty (if you still have it).
Sep 06, 2007 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
583 people viewed this question
Top Televison & Video Experts
