XP won't boot without IBM 10/100 EtherJet NIC
I installed a second NIC in an XP Pro box to off-load files on a crashed drive. Two days later, I removed the NIC (IBM 10/100 EtherJet) and rebooted. Now I keep getting a missing media boot error.
Although I've done this many time, this was the first time I've done it using this computer. I've since reinserted the NIC, and it boots right into XP not fuss.
Anyone now how to fix this? Thanks in advance.
  • Charles Fields
    Charles Fields May 11, 2010
    What is the exact message please
  • 463 Answers
Check the BIOS to make sure the machine is not trying to boot off of the network card (PXE boot) and make the hdd in question the primary boot device.
Posted on Mar 05, 2009
  • Rob
    Rob Mar 05, 2009
    If the above does not work, disable the on-board lan adapter and see if it will boot.
System Commander 9 fails setup
Have you tried loading System Commander 9 without Linux? the reason I ask is when you run a dual operational systems there tends to be issues that come up with certain programs, there have been to many problems with this type of settup.
Apr 17, 2012 | Computers & Internet
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
I have a ibm 10/100 etherjet cardbus adapter and am trying to get it up and working on my laptop that is running windows 7. Previously when i was running windows xp it work perfect but since i installed...
Unfortunately, this adapter is 10 years old and Microsoft and IBM have decided that you've used this network adapter for quite long enough and you need to buy a new one.
Microsoft and IBM have not and probably won't provide drivers for Windows 7 for this adapter. I looked at the Lenovo/IBM web site, and the last version of Windows that was supported by IBM was Windows XP. There are no drivers listed for Vista, so I'm very certain that there will be no drivers for Windows 7.
This is what is known as "planned obsolescence"
Dec 30, 2010 | IBM 10/100 EtherJet CardBus Adapter
Gigabyte Ga-K8N Pro Windows XP Installation
Download "MEMTEST86+" from the Internet.
One version boots from a diskette;
another version boots from a CD-R (that you have created).
Either way, make MEMTEST do a "full" test of the RAM in your computer -- bad RAM can cause "unpredictable" crashes.
Sep 13, 2009 | Gigabyte GA-K8N PRO nVIDIA nFORCE3,...
Windows 2k Pro crash with HP J5780 printer and M50 Thinkcenter
Assuming you have SP 3 on 2000, it's possible the USB ports are bad.  Try a different USB device ie mouse, flash drive etc to verify whether the USB port is bad.  If this is the case, you can either purchase a USB 2.0 card and install it on your PC or run without USB ports.
Sep 01, 2009 | IBM ThinkCenter M50 (8189A1UJ) PC Desktop
Intellistation Dreaded "ntldr not found"
You have the solution given the fact that the IBM netloader wants to be subordinant to a loaded OS on a different drive acting as server when used on a thin client like the Intellistation. Unless carried as a portion of the registry of an MS OS, XP or Vista will drop it unless registered with a NetUpdate as a standing part of the registry. But most sysops conduct updates without all clients active so that some will inevitably be dropped, which is why the best strategy is to conduct updates on Off Hours when all clients can be up without human interaction, impossible during the workday, unless you deactivate an entire set of nodes for the purpose.
Run a reregistry while the Intellistation is on and active but without an operator and your problem should disappear more permanently.
Apr 21, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
T40 intermittently crashes and recovers "from a serious problem"
If you have not upgraded of changed your power supply, you probably should. Also, you could be having troubles with your RAM. Have you try to perharps repair or re-intall window?
Let me know
Apr 13, 2009 | IBM ThinkPad T40 2373 Notebook
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
2 ethernet cards can't work together
If in your network you are connecting computers directly to a PC thru multiple nics and not a router or hub leaving one as server and the others as clients and that server is NT 4,0
NT 4,0 can not auto configure the cat5 cable and would need at least 1 cable to be a cross-over and not a patch.
Apr 01, 2008 | IBM NetVista A40 PC Desktop
Doesn't install properly on Thinkpad 760XL running WIN98 SE
Make sure you have all the drivers handy.
Uninstall the sound
Uninstall the modem
Uninstall the nic drivers as well as the wirelss nic drivers.
Uninstall all others that have conflicts.
Remove the adapters out of the pcmcia slots. (Ethernet, etc
Shut down and restart the system.
The system should detect all hardware again.
Now if this laptop has an onboard nic and modem disabled them
Shut down and restart system.
Check control panel to make sure they are diabled.
Now istall the combo card nic/modem.
If this does not work you should try diabling them in the bios.
As for the wireless nic. You normally would have to install the software prior to inserting the adapter.
Let me know what happens
Hope this helps you
Nov 02, 2007 | IBM EtherJet Network Adapter
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
