Question about HP Photosmart C6380 All-In-One InkJet Printer
Photo paper when put in photo paper tray won't feed into printer
Did you check the size of the paper in which you intended to print on(Properties of Printer on PC).If you did try looking for a a small slider on your printer to match the size of the paper.
Posted on Apr 09, 2009
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Apr 07, 2011 | HP Photosmart C8180 All-in-One InkJet...
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
Paper jam
Hi! In you case, you have to put not thick photo paper in your printer.
Mar 20, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Wont feed glossy photo paper
Clean the feed roller(s) with a cloth dampened with alcohol. They are probably slippery with paper dust.
Mar 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
Paper Feed Problem for 8.5x11 Photo Paper Pro
Please check out the roller and paper setup on the tray, Clean it thoroughly.
Also make the Printer to put it on a Horizontal table if any inclination there.
Regards
Ellin
Apr 25, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Photo Paper Catasrophy
Does it try to take the paper?........
....yes......Dirty paper feed rollers, clean rubber rollers with slightly damp rag
....No....... Paper/tray not installed correctly or sticking / dirty paper out sensor
Sorry cant help further cant picture model in mind
Oct 21, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart C6380 All-In-One InkJet Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
