Question about KitchenAid KESC307 Electric Kitchen Range
Sabb fixed...now err with temp.
Now that I got it off of Sabb mode, I put in a temperature and it says err when I push start.
    President:
  • KitchenAid Master
  • 2,651 Answers
Posssible that youve now switched from farrenheit, to celcius. manual will explain how to shift back
Posted on Mar 08, 2009
87 bronco2 2.9v6
Most likely is the temperature sending unit/sensor. Nobody ever thinks about how it works. When engine is started, and cold, the temp sensor tells the computer to put the engine into cold start mode, putting more fuel into the engine and to a bit higher idle. Once it warms up to operating temp, said sensor tells the computer to turn off cold start mode and it stops dumping excess fuel in. If the sensor puts it in cold start mode, malfunctions and doesn't take it off cold start mode, it's still dumping excess fuel in and flooding the engine. Sometimes a re-start will reset the computer, but not always. Makes sense now, doesn't it. Find the temp sensor and replace it like you did all the others.
Nov 29, 2017 | Cars & Trucks
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
I turn on the power and before I can set the temperature I get a flashing "err" message and can't do anything.
You are not alone. We have the same problem. Unit worked fine for 2-3 years. We still have the manual. This is not a user error- we know how to use it. The sensor switch is fine- it would not power on without that working ok.
The red power light comes on, and when we turn it ON it says "200" for about 2-3 seconds... then "Err". Nothing is possible after that, the unit has to be powered off.
We can push Temp Mode and start setting the temp higher but after 2 seconds it just goes to Err. It does not matter what buttons you push- you don't have to push anything at all and it says "Err". Reset button does nothing- this is not a heat temp overload issue. This unit worked at Thanksgiving, and then not at Christmas! We tried powering it on 10-20 times... nothing. Then the next day as we were about to put the turkey in the oven I tried the fryer again... and presto it worked fine!!! Now today it does not work again. Tried it 10 times, no go. Unit was stored in pantry (in house) so it is not a cold/warmup issue. I think it is something messed up in the electronics- a weak solder joint, a bad chip, who knows. It's like the unit fails a "power on self test". Unfortunately, I do not have a solution yet. Don't want to buy another Masterbuilt for sure... only use this 1-2 times a year. Will share if I find anything.
Nov 26, 2010 | Masterbuilt 20010306 Deep Fryer
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
Whirlpool Stove oven temperature not accurate
This unit has a calibration function which can compensate for temperature errors of +/-30 deg F. Hold the BAKE button for 4 seconds to enter this mode. Use the Temp UP/DN buttons to adjust the temperature offset. Push START to enter the new offset.
Also, the typical manual oven thermometers are notoriously inaccurate.
If this doesn't solve your problem, next items may be the temperature sensor or control board. If it is the control board we may be able to repair it for you at www.fixyourboard.com.
Jul 13, 2009 | Kitchen Ranges
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Err Code 210
What you need to do is check the resistance of the booster tank temperature probe. The error 210 means a short circuit in the booster temp probe. At room temperature, the resistence should read about 1k Ohms. If you are reading significantly lower than that, then you will need to replace your booster temperature sensor. You also want to check the 4 pin square molex connector on the I/O board on top. Make sure all connections are tight, secure, and that there are no "bridges" across the connections for the temp sensors.
Feb 19, 2009 | Meiko FV 40.2 Dishwasher
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
KitchenAid KESC307 Electric Kitchen Range Logo
129 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
