My tv screen is a single horizontal line. - Televison & Video
    Problem Solver:
  • 8 Answers
Just check the vertical section, might be lost contact vertical IC. Just resolder.
Posted on Feb 26, 2009
chrispurs1
  • 372 Answers
SOURCE: Toshiba 32d46 single horizontal line in center of tube
Hi. Check the frame output IC for dry solder joints.
Posted on Sep 16, 2007
  • 163 Answers
SOURCE: JVC AV 35750 single horizontal line
Wow I miss these days.. Replacing 100UF caps for Vert. circuits on old RCA's and similar.. Got into Laptops now but happened-stanced on this website and the Premtech knows what hes doing.. (Remember the GE/SYL chassies w/ Cold joints in the integrated tuners)?.(snowed out) Thousands). Have fun guys and I'm here to help as well. (Laptops High end stereos, and Hi-def TV's only please).. (Hate telling people their toaster ovens are replacable.. (Blue haird's) Good posts!
Ken
www.ikenfixit.com
Posted on Jan 13, 2008
  • 2326 Answers
SOURCE: Panasonic CT-32G6E Intermittent single horizontal line
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Posted on Aug 07, 2008
SOURCE: Thin Horizontal Line on TV screen
I had the same problem on a 36" Hitachi TV about 7 years old. After reading comments on this and other pages I went and bought a soldering iron not knowing what I was going to do with it.
After trying to find a loose connection with the power off- with no success, I then tried with the power on. Not the smartest move, but I was able to find the problem.
If you follow the colored wires (blue, green, red, yellow) from the back of the tube they will come together at a connector that plugs into a card at the bottom of the set. That connection was no secure. Since reseting that connection I have had the clearest picture since puchasing the TV new.
I am sure it is obvious that I don't have an electronics background, and I don't have an explaination as to why this worked. I just know it did. I hope this helps someone.
Posted on Sep 20, 2008
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Magnavox ts2543 with a single horizontal line
Most Probably the Vertical Output IC has failed. If it has, it also could cause resistors that supplt the +/- Voltages to the IC to fail as well.
Hope this helps,
Skyassoc
Jun 20, 2009 | Televison & Video
Screen goes to horizontal line
Maybe the vertical IC got some cracked solder joints and the reparation worth it
Apr 24, 2009 | Televison & Video
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Single horizontal line
this problem is field collapse usually causd either by the field oscillator or field output stage to advise you further i would need to look at the circuit diagram
Feb 09, 2009 | Philips Magnavox 27MS343S 27" TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
