Question about Goodman GMS90703BXA Heater
Fuse Blows when diagramed wiring is used on GMP125-5
I use 3A and 5A fuses. Wired everything just as it is in the service manual and it blows a fuse almost everytime. I've tried variations of grounding...I know the unit is good, but am baffled. Was able to get it to run the cooling system but it wound up bypassing the heating system. it's almost like it's telling me "you can only have one or the other bubba!"
    New Friend:
  • 92 Answers
I would check your thermastat wiring if you blow the fuse you have a dead short those fuses are saving you alot of money. remove all wires from terminals for t stat on furnance and jump between r and w if it works your problem is in wiring ..........
Posted on Feb 26, 2009
HOW TO SOLVE EMC1 FUSE THAT KEEPS BLOWING
The ECM 1 fuse powers the computer, evap system, injectors, and various other components. You would need to trace these circuits to find the short.
The Haynes manual wiring diagram does a poor job of showing you everything on this fuse, so you may need to get a used shop manual to find everything.
As with any short problem, you need to disconnect everything and see what blows the fuse as you reconnect it. You could use a circuit breaker that plugs into the fuse slot for the testing procedure.
Mar 09, 2013 | Cars & Trucks
My #20 fuse in the engine compartment is blowing, which is a 15 amp fuse
You look up the circuit that blows the fuse in your owners manual
You then need wiring diagrams to figure out why a fuse blows &
solve the problem,you don't replace the fuse, only to have it keep
blowing
Feb 08, 2013 | 1999 Ford Windstar
2007 harley heritage blows turn signal fuse
Hi Anonymous, check your handlebar switch housings for pinched wires and for a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Apr 26, 2012 | Harley Davidson FLSTC Heritage Softail...
I have a BMW F650 Gs 2003 model. Problem.... Resent 40k service done and now it keep blowing 15amp fuses. They ( the service people) have checked everything. can't find the short. It only blows fuses when...
Which 15Amp fuse blows?? Sounds like a pinched wire in the area of the headlight/instrument cluster. Remove the faux gas tank cover center section and maybe also remove battery. check in front of battery compartment for pinched wires etc.
I can offer more help if you post which fuse blows. I can look on wiring diagrams and tell you which items are powered from the fuse in question.
Sep 21, 2010 | BMW F 650 GS Motorcycles
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
Don't know what fuse is what .10 amp blows right
try different fuses starting with lowest then go up but think it is a 30 amp fuse ?
Oct 08, 2009 | 2001 Jaguar XJ8
2002 F150 SuperCab Power Windows via 5A radio fuse. Wierd!
The location for the circuit breaker is in the fuse box under your hood number 601. Its a 30a CB.
Aug 09, 2009 | 2002 Ford F150 Regular Cab
99 dodge neon # 10 fuse ing feed 15 amp blows out
There's a short in the circut. Check continuity of the wires that feed from that fuse (you'll need a wiring diagram to identify each wire). You've got something that is causing too much amperage to move through the circut and the fuse blows. Make sure the amperage on the fuse is correct for the application (your owner's manual or fuse box diagram should tell you what amperage rating to install in each fuse slot).
Jul 03, 2009 | 1999 Dodge Neon
I HAVE A 1985 K30 6.2 DIESEL 4X4 MILTARY PICKUP
The reason the fuse blows/melts is because there is excessive draw. The other alternator could be wired wrong. Check to make sure the wires are correct gauge.
Nov 13, 2008 | 1985 Chevrolet Chevy
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Goodman GMS90703BXA Heater Logo
112 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
