Question about Epson Stylus C46 InkJet Printer
Won't print I have a Epson 4750 All In One Printer - I put in all new ink cartridges - the machine still says out of ink - I have taken them in and out several times - yes they are the correct cartridges - The out of ink light stays on -
  • 203 Answers
Silly question first, have you taken the film of the cartridge connectors?
if not then do.
if you have removed then my hp printer has done this and as far as i am aware it is due to the connections on the part that holds the ink cartridges. they wear down the same as on the cartridge.
this makes the machine not able to see the cartridge.
Posted on Feb 26, 2009
Why won't it print or scan?
How To Unclog Brother Multifunction Inkjet Printhead Nozzles
www.inkmagic.com/shopcontent.asp?type=Unclog...Inkjet_Printhead...
Many Suggestions and Directions to Unclog you Brother Multifunction Inkjet ...problem when a new cartridge is put in, your Brother printer will do a priming. ... So, before you blame the compatible cartridges for your Brother printer not printingproperly, ... Many companies want you to believe that "one ink does all printers".
How to Unclog Epson Printhead Nozzles - - InkMagic ...
www.inkmagic.com/epson_clogged_printhead.htm
Clogged nozzles - Epson printers Epson printers have a built-in, permanent printhead.... To overcome this problem when a new cartridge is put in, your Epson printer ... If you manage to get all nozzles printing after 6, 8, 10 or more cleanings your ...InkMagic International remanufactured 2,000 - 4,000 HP inkjet cartridges a ...
All-In-One Printer Fails To Print Black Ink? - Super User
Jan 05, 2016 | Epson Inkjet Multifunction Machines;...
My epson xp-200 printer with won't print with the recommended ink cartridge epson 200. why?
The printer may only work with Epson ink cartridges and not compatible ink cartridges.
Sep 15, 2012 | Epson Expression Home XP-200 Wireless...
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
I put new ink in it, now it won't print, it is
If you only filled the cartridges with ink they will not work.
The chip on the cartridges needs resetting.
To do that you would have to buy an Epson cartridge chip resetter..
Feb 20, 2010 | Epson Workforce 30 Laser Printer
I put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Office Equipment & Supplies
Cannot put in my black ink into my epson stylus dx 6050
You can download the manual from here, which gives a full explanation on changing ink cartridges:
http://esupport.epson-europe.com/FileDetails.aspx?lng=en-GB&data=dkmEK02SU002FerSswuKrCsBh8QsoyzJb18U&id=8383
You can do it manually by turning on the printer, then, as soon as the print head starts to move, pull out the power cord from the printer, or switch off at the mains. The print head will now be free to move (carefully) by hand to the cartridge change position. Replace the cartridges and turn the printer back on. Carry out a cleaning cycle.
If the cartridges have been out for a while, you will no doubt have dried ink blocking the nozzles. Several cleaning cycles may be needed, or other methods, to clear the print nozzles. Report back if this is the case.
Remember in future not to remove a cartridge until you are ready to replace it.
Jan 31, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson R280
Don't try to fix it. Put the machine back in the box and return it Epson for a new one. Do it before the machine is 28 days old or they will give you a graded machine.
The error can be caused by the cartridges themselves but best to get the whole lot exchanged.
Sep 08, 2008 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
