Question about Nintendo New Super Mario Bros. for DS
I need a level 6
At the moment i am a level 5-
i need to get level 6
can you help me by telling me what to do to get it
    Problem Solver:
  • 6 Answers
Finish 5 as a mini.
Posted on Mar 02, 2009
Need info on how to change a 2000 Cadillac
REMOVAL PROCEDURE
TOOLS REQUIRED
A J 34730-1A Fuel Pressure Gauge
A J 39765 Fuel Sender Lock Nut Wrench
CAUTION: Refer to Batterry- Disconnect Caution in Service Precautions.
1. Disconnect the negative battery cable.
2. Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure. See:
Fuel Delivery and Air Induction/Fuel Filter/Fuel Pressure Release/Service and
Repair
3. Drain the fuel tank. Refer to Fuel Tank Draining Procedure. See: Fuel Delivery and
Air Induction/Fuel Tank/Service and Repair/Procedures
4. Remove the fuel tank.
5. Remove the fuel sender assembly.
6. Disconnect the fuel pump electrical connector (5).
7. Remove the fuel level sensor electrical connector retaining clip (6).
8. Disconnect the fuel level sensor electrical connector (7) from under the fuel sender
cover.
9. Remove the fuel level sensor retaining clip (4).
10. Squeeze the locking fangs and remove the fuel level sensor (3).
INSTALLATION PROCEDURE
1. Install the fuel level sensor (3).
2. Install the fuel level sensor retaining clip (4).
3. Connect the fuel level s ens oi electrical connector (7).
4. Connect the fuel level sensor electrical connector retaining clip (6).
5. Connect the fuel pump electrical connector (5).
6. Install the fuel sender assembly.
7. Install the fuel tank.
8. Refill the fuel tank.
9. Install the fuel filler cap.
10. Connect the negative battery cable.
11. Inspect for leaks.
11.1. Turn ON the ignition for 2 seconds.
11.2. Turn OFF the ignition for 10 seconds.
11.3. Turn ON the ignition.
Aug 29, 2014 | Cars & Trucks
How many n what kind of oil i need to use for a nissan quest 1999
If it has the 4 cylinder in it 5W20 and if you have the 6 cylinder it could be either 5W20 or 10w30. I usually use 5W20 in cold months and 10W30 in hot months. As far as capacity goes, as a general rule if you change the oil but not the filter, not something I recommend, then you start with 4 quarts and adjust from there (Basically by 5 quarts). If you change the oil and filter then start with 4 and a half quarts and check the level and adjust as needed. You could use up to 5 quarts maybe a little more. Make sure you check the level before starting then start the vehicle for 5 minutes shut it down then check the level again after 5 minutes. Make sure the level is between the marks.
Aug 24, 2011 | 1999 Nissan Quest
I have a 2004 54 plate jaguar x type 2.0 v6 fault code P0346 comes up on scan camshaft position sensor a- bank 2 need help to locate the sensor thank you to all that can help me
http://www.bluejag.co.uk/Jaguar-XType-Engine-2L-V6.php
I haven't finished this page yet so it's only a guide to location at the moment. location 5 and 6.
If you disconnect the sensor and check your error code you will be able to tell which is which (if you get a new code its the wrong bank).
It may pay to check your spark plugs in the bank concered, if the resistance of plug(s) go high this will also cause this fault
Aug 21, 2011 | 2003 Jaguar X-Type
How do I add transmition fluid to my cadillac srx?
Under the hood the handle will be red in color and say trans. on it. Remove this and this will tell the level of fluid thats in it, engine needs to be warm before checking the level. This same port used to check the fluid is the same place to add the fluid.
Please take a moment to rate my answer.........Thanks
Dec 01, 2010 | 2005 Cadillac SRX
New Super Mario Bros. Wii. Haven't received beaten game message!
Do you have 5 stars on you file on the main menu?
1. Successfully complete the game. 2. Successfully complete all normal levels. 3. Collect all 207 Star Coins in Worlds 1 through 8. 4. Successfully complete World 9 with all 24 Star Coins. 5. Successfully complete all levels with all alternate paths (all Warp Cannons and Mushroom Houses used). 6. Successfully complete all levels without unlocking the Super Guide Block (do not die eight times) to unlock sparkling stars.
If you do have 5 stars then don't worry, you have beaten the game, don't fret.
Feb 11, 2010 | Video Game Consoles & Games
Set call rings
From the manual:
1. Press the CALLER ID-VOLUME ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press mute/menu OK button to enter the menu. SET RINGER LEVEL 5 shows in the display.
3. Use the CALLER ID-VOLUME ( 6 or 5) button to scroll to your selection. LEVEL 5 is the default setting.
4. Press the mute/menu OK button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
Apr 26, 2009 | General Electric 28811FE2 Twin Cordless...
I can't find a way to world 6 for super mario brothers, ds lite
you need to beat the castle in level six while being mini- mario and it will open up level 7.
Feb 18, 2009 | Nintendo New Super Mario Bros. for DS
Tile floor installing
you need to have all the equipment and goods. The tiles, cement to fix them, the cutter, a level, a rubber hammer, a marshy, a water drum, and paper.
1. use the paper to cover all the area that may be damage.
2. level the surface
3. put the title in the level floor, without pasting them, and measure the titles you need to cut, to fix all the are, measure and align them.
4.with the marshy apply the cement to the area
5. Put the titles and with the robber hammer hit them softly.
6. went finish clean them with a soft rag and water.
Oct 02, 2008 | Measuring Tools & Sensors
To increase up volume
The code is: *#0206*8378#
Then go in: H/W Test > Audio Settings > MP3 spk
change 'ear gain' to 14.
Then, enter 'Rx vol.'....
I made this changes:
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
I made this changes and the sound of mine became very loud now...
You can do your own changes,
Jul 21, 2008 | Lands Phones
Nintendo New Super Mario Bros. for DS Logo
47 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
