Question about Belkin (F5D7230-4) Router (587009)
Connected with limited access
I have a Belkin FSD7230-4 router , which I have recently transferred to a new computer running Windows XP; I had previously been using it with Vista. The connection dialogue box gives me a message saying 'Connected with limited access' and when I try to use Internet Explorer, I get the 'Page is not available' message.
  • 37 Answers
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Start
-Control Panel
-In Classic View, select network connections
or
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Posted on Feb 26, 2009
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Does Belkin transfer programme files?. Also I want to know if this product transfers from XP to XP, desktop to desktop. Basically, I am moving from a 20gb to 80gb hard drive and want everything to be in...
A transfer cable kit will only transfer files and settings to another computer. What you want to do is have your 20GB hard drive imaged to a clean 80GB hard drive. That would transfer everything and give you extra space.
Some people call this "Ghosting" using a product from symantec called "Ghost" and another product that can be used for free (home use) would be "Drive Image XML" .
I would suggest going to your local Computer Shop and requesting this type of service.
Mar 13, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
I cannot run internet with my router
downgrade your vista to windows XP Pro or XP home..
Nov 07, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7230-4) Router (587009) Logo
727 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
