Question about Kenmore 4292x Front Load Washer
Machine continues to agitate in the spin cycle
Kenmore 70 series model 22702 . daughter overloaded machine. now the machine won't spin but agitates when it should be spinning
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmore 70 series model# 22702 will not spin
Kenmore model 70 washing machine fills with water, doesn't agitate, spin or anything else. Could it be the closed lid sensor? Friend says it broke in two. I told them to unplug power, pig-tail two wires together to complete circuit isolate from all metal and plug power back in, and see if it cycles. Is that advice a good start? Will try to re-post if he calls back and says if it worked or not and we'll go from there. Thanks for replies.
Jul 08, 2010 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
My Kenmore series 70 washer will wash and then the machine stop. If I move it to the rinse cycle it will start agitating again and then it will shut off again. It seems li9ke the spin cycle isn't working
Welcome
Either of these three problems may be occurring.
Faulty Direct Drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The Direct Drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
All functions operate normally except the machine will not agitate.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This wil require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Thank You Please remember to leave a rating.
Dec 12, 2008 | Kenmore 23822 Top Load Washer
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 4292x Front Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
