Question about Hoover U5444-900 5100 Wind Tunnel 15 Inch Wide Hepa Filter Bagged Black VacuumVacuum
I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
I need step by step instructions to change the belt... thanks!!
  • 294 Answers
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Posted on Feb 28, 2009
My sweeper won't pick up anything could the belt be broke
It may be broken or it may be stretched. Belts can become stretched and will lose elasticity.
Jan 26, 2011 | Hoover U59 WindTunnel TurboPOWER Bagged...
Hoover Turbopower Wind Tunnel V2 - clogged - cannot find a way to get at the clog - HELP!
i took off the bottom black piece...removed the brushes ..took a coathanger and went down in silver dollar sized hole and got a big clog out...i also removed the black hose on the back at the very bottom...and used a coathanger up in there as well. mine is picking up some..but ive still gotta clog myself...i was hoping to find an answer here...-_-
Jan 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover U5444-900 5100 Wind Tunnel 15 Inch Wide Hepa Filter Bagged Black VacuumVacuum Logo
849 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
