Question about Olympus SP-310 Digital Camera
Lines through all pictures
Recently I am having vertical lines through all pictures and now the back screen is black and blank.
    President:
  • 919 Answers
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $89 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 22, 2009
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
One White Horizontal line on black screen
replace the vertical IC problem solved
Dec 31, 2007 | Sanyo DS25390 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Olympus SP-310 Digital Camera Logo
95 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
