Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gas range MGRH865QDS oven code 5A6 6ATH held timer and clock buttons down no work unplugged from power, returns flashing for two seconds then back to 5A6 6ATH
  • 5911 Answers
SOURCE: I have a error code of 596 6ATH and cant seen to
The error your range is displaying is actually "SABBATH", which is Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question uder is correct, the instructions for Sabbath mode are listed on page 14 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
Posted on May 01, 2010
Testimonial: "I was able to reset by holding in the clock button for about 5 seconds and it all went back to normal. Thanks"
SOURCE: Amana Range, M# AER5515QAW
I found the solution on a "solution" section right here! the range may be in the "lock" mode. Press the "clock" and the "bake and hold" buttons together for 3 seconds then release. You may have to repeat this if your display still says "lock".
Posted on Dec 22, 2008
  • 641 Answers
SOURCE: error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Posted on Jun 08, 2006
  • 473 Answers
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
SOURCE: Maytag Gemini Gas Double Oven
turn off the circuit breaker for a minute or two -- or unplug the range.
Posted on Jan 18, 2008
We had some sort of electric power failure last night lasting only a few seconds, but now none of the control buttons on the gas range function. In the time window 5a6 shows. No way to use the oven.
You are in Jewish Sabbath Mode, it is 'Sab'
Search Results Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab". To disable the Sabbath mode push and hold the Clock pad for 3 seconds.Nov 10, 2007
Maytag Oven WEIRD Error Code 5ab - Appliance Repair Forum Feedback
About this result
Will you tell me what error code 5A6 means on Maytag MGR6875ADQ ... Nov 24, 2010 - As indicated in the previous response, the 5A6 indicates that the range is in the Sabbath mode (SAb). The image below shows the information on this mode for your range. Press the CLOCK button and hold it for 3 deliberate seconds to cancel this Sabbath mode. The control should then work normally. what does the f-2 error code on my maytag oven mean?
26 Jun 2010
What does the SAB error code mean on my Maytag ...
1 answer
1 Jan 2010
How do I cancel the Sabbath mode on my Maytag range?
30 Dec 2008
What does an SA6 (or 5A6) error code mean on my ...
1 answer
13 Nov 2008
More results from
Maytag Oven SAb error code - YouTube
? 0:54 Jan 1, 2014 - Uploaded by Life With Christ
The SAb error code will freeze your oven functionality and you will not be able to cook or program the oven ... Oven Repair including Ranges and Cooktops
Mar 12, 2018 | Kitchen Ranges
How do I change the oven temp from celcius to farenheiton my Maytag Advanced System Model #MGR5710ADW
try unplugging range. If it does not return to F display
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit.
Read more:
Read more:
Jul 15, 2014 | Whirlpool Gold GW399LXU Gas Range
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Sep 28, 2007 | Maytag MER5775Q Electric Kitchen Range
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
276 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
