Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan wt 200 blower, no spark
Won't start, replaced plug, checked spark and there is no spark
  • 398 Answers
Are you sure there no spark sometimes u cant see it in daylight. if there is no spark you need to trace the wire down inspect for damage and inspect for loose/rusty connections. then let me know
Posted on Mar 20, 2009
I replaced starter on 1989 f150 5.0 now have no spark
Mike, Check for diagnostic codes. Check fuses/relays,wires/plugs for pinched,damage or corrosion. Could be a lot of things like distributor armature, cap, rotor, stator, ICM, coil,spark plugs,wires, make sure ground is good to distributor. Use the attached forum links,instruction, guides to help diagnose ignition spark problems, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
No spark replaced all ignition parts 1990 F150 Ford F150 Forum Community...
Engine Spins but No Start No Spark
Engine Won Start No Spark
Code Reader 80 96 Ford Bronco
Resolved 89 Ford F150 302 Won Start HELP
Jun 24, 2016 | Cars & Trucks
Yamaha yn 50 got a spark just won't start what
Check there is fuel getting to the spark plug-turn it over and then check the spark plug is wet. Also check the air filter is clean. Remove the filter and see if it will run. If it does then replace the air filter.
Jun 26, 2013 | Motorcycles
My 1991 Ford Tempo won't start. It turns over but doesn't spark. The battery has been replace, checked fuel pump and spark plugs but it still won't turn on. Help?
change the ignition pick up coil assembly normally located on the distributor under the rotor on the bottom of the distributor or just replace the distributor
Jan 30, 2013 | 1991 Ford Tempo 4 Door
Won`t start
check for spark by pulling of the spark plug wire remove the spark plug and pull the engine over while holding the spark plug against the cylinder head
Sep 10, 2012 | Garden
My car won't start,seems like no spark?/,just turns over and over
before u replace the whole dist. have u first checked for fuel delivery on the carb or fuel rail, and then if u have that then check the spark plug wire by removing one while cranking by arcing to metal , if you see spark then dist is good if not then replace, but if dist is good and still no start then check coil pack and or all fuses
Apr 25, 2012 | Cars & Trucks
Toro snowthrower model # HSK 635 won't restart, stated first time, ran about ten minutes, then died, put brand new spark plug in, getting good spark, just won't fire up, even when I tried a li
check and make sure its getting fuel. when trying to start, spray some engine starting fluid in spark plug hole. just a little bit. replace the plug then try to start it. if it starts then quits then its a fuel problem. fuel not reaching engine. good-day !
Jan 30, 2012 | Garden
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
1994 camry won't start after cleaning under the hood check dist. cap replaced spark plugs sounds like its going to start then doesn't.
Sounds like wet or moist spark plug wires. If this also occurs during early morning high dew point humid air, then you may have spark plug wires shorting out.
Replace wires.
Jul 02, 2011 | 1994 Toyota Camry
Won't start after washing it, tries to turn over just won't start
check / remove the spark plug from cylinder head ,clean and dry them both,might water gets into it...
possible should adjust the spark plug tip allowance,make it slight closer.
or try to replace another spark plug. good luck..
hope it helps... please rate me if this is helpful...thanks
Jun 05, 2011 | Suzuki GSX-R 750 Motorcycles
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
1,030 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
