Question about GE 24 in. Profile PDW8680JSS Built-in Dishwasher
Dishwasher has no power. Running fine 'til this point...
Checked the breaker (obvious), no problem there. Took off the front cover to check the connections on the Module Control Assembly. Nothing looks wrong. I'm assuming I have to pull it out to check where the power comes in. Has anyone ever had an issue like this?? Are there fuses somewhere on this unti that could have blown?? Or a short??
Thanks!!!!
Dave
  • demoulpied Feb 26, 2009
    Thanks very much for the quick response nailuj12!! I'll check this out tonite....
  • 117 Answers
Hi Dave
Make sure that with power off you check the interlock switch. When the door closes the actuator closes the switch(s) to continue power. Make sure that door strike is entering the latch assembly ok when the door is closed. Also with the circuit breaker off, make sure the wires at the junction box are in order. Here is the interlock switch assembly. Good Luck!!!!!!!!
Posted on Feb 26, 2009
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Our dishwasher doesn't turn on--no power. I have
There is sometimes a switch mext to the disposall that switches the dishwasher on & off. if no luck revers the 2 plugs just to see if it will come on if not then check that the plug is hooked up under the front of the dishwasher behind the cover at the bottem.
Sep 12, 2009 | KitchenAid Dishwashers
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Whirlpool Dishwasher model gu980scgq3
Hi vicyoung0921,
I'm Harvey the Master Plumber.
Your question is: Will not start, seems to have no power at all. You checked the breaker and it's fine. Is there a reset button somewhere on this dishwasher ?
No reset, if breaker is good then check the connection at the d/w. It's under the d/w behind the kick plate on right or center under a cover box. 9 times out of 10 you'll find a loose, broken or burnt connection there. That done, it's time to call in warranty repair. If beyond warranty you might consider utilizing the Repair Directory to find a repairman. If the d/w has a few years on it perhaps it is time to compare the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Dishwashers
No power after one months usage.
Hi Red15,
Your question is: New dishwasher was working prerfectly and now it will not power up.
You checked the breaker it's fine and I checked the outlet for power.
The dishwasher will not power up. There was water at the bottom of the tub so you took out the filter removed the water and cleaned out the drain pump.
Still no power. Any suggestions on what to do next?
I see this all the time! Your problem is electrical. 9 times out of 10 you'll find a loose, broken or burnt connection in the junction box. Turn off the breaker first, we're not going to get a shock. Look under the d/w and behind the kick plate. You'll find a small metal box on the right or center. Remove the screw. You'll then find the hard wire connections we're looking for. Take wire nuts off one at a time (so we don't confise them). Inspect carefully. Replace wire nuts and restrip wire ends as nessessary. Test the unit before replacing box and plate, there's a chance you might have missed something. Confirm d/w is working then recover.
Thank you,
Sep 11, 2008 | Miele G 2630 SCi Stainless Steel Built-in...
JDB3610AWX - Controls (pushpad) does not respond to input (doesn't turn on, led doesn't light)
in the manual there is a sequence to unlock the control check the manual for the unlock sequence
Apr 25, 2008 | Jenn-Air JDB3610 Built-in Dishwasher
Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Feb 18, 2008 | Dishwashers
GE 24 in. Profile PDW8680JSS Built-in Dishwasher Logo
168 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
