Question about HP LaserJet 4650n Printer
Display reads "card slot not initialized"
How do you initilaize the card slot for the 4650?
    Genius:
  • 2,120 Answers
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Posted on Feb 27, 2009
  • Leroy Elliott
    Leroy Elliott Feb 27, 2009
    It's on page ID 10T of the manual
Why my pc shutdown itself after i install graphic card ATI HD 4650... hurmmm
Make sure that the vga card is properly seated on the slot, or you can also check if the vga is compatible with your motheboard.
Hope this one helps. Thanx
Apr 03, 2011 | ATI ALL-IN-WONDER 9600XT 128MB AGP DVI...
HP 4650 turns on, does the count up to 128MB, HP logo appears then it stops and only "initializing" on display.
Remove the Jetdirect card and try it. These tend to cause this fault. If not, possibly down to the formatter board
Oct 12, 2009 | HP LaserJet 4650 Color Printer
HP 4650 hangs at initializing
Remove the jetdirect network card. Then power it on and see if it goes ready. If it does then it could be a fault with the jetdirect card
Oct 06, 2009 | HP LaserJet 4650 Color Printer
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Initilaize panoramic sun roof
Have window closed. Press the vertical vent button (press in towards roof). Hold for 20 seconds and the window will start to open, keep holding button until the window goes all the way back and then all the way forward. BMW's initialization procedure.
Jun 15, 2009 | 2005 BMW X5
HP 4650 stops at "initializing"
REMOVE THE BATEERY IN THE CARD AND DO COLD RESET
Apr 20, 2009 | HP LaserJet 4650 Color Printer
My Printer has an Error Message saying "card slot not Initialized
Try this.
1. Turn the printer on.
2. When the memory count start Press and Hold the "Menu" button.
3. Release the "Menu" button when all 3 LEDs are illuminated.
4. Press the 'back' button.
5. The display will then show "Initialize disks".
6. Press the green "Check" button to start the process. This will take some time.
7. The printer will automatically come back to "Ready" after this procedure.
If the above doesn't work, you may have a bad memory card.
Jan 22, 2009 | HP LaserJet 4650 Color Printer Manual...
ERROR CODE 81.018,E101
According to my reserarch this error usually refers to an EIO card error in slot 1.
you could try reseating the card , maybe in another slot.
A firmware upgrade could help.
if those don't help it may need a new card.it can't hurt to check any cables, make sure nothing is lose
Angela
Aug 29, 2008 | HP LaserJet 4650 Color Printer
EliteGroup ECS AMD690GM-M2
get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Jun 13, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Message "Card not initialized"
make sure the camera is in teh taking picture mode...then click the MENU button...scroll all the way down to SET (SET-UP)....click right arrow to select...then scroll down to FORMAT...click the right arrow...it will say, "FORAMT OK? / ERASE ALL DATA" click OK...it will take a few seconds to erase and from there...the "card not initialized" should be gone!
Aug 22, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
HP LaserJet 4650n Printer Logo
1,182 people viewed this question
Seeker5211
Seeker5211
