Question about Panasonic Technics SL-DZ1200 Turntable
Sldz 1200 cd jump
Help!
I have bought a sldz 1200 cdj second hand and it has a fault.
In cd mode the sound is perfect and plays freely.
In vinyl mode the cd jumps and skips. music does not flow freely.
i am yet to mix using this cdj and it is really depressing.
Please can someone help.
I am based in Leeds, UK if anyone knows any technicians.
Thank you
Oz
  • Anonymous Mar 24, 2009
    Apparently this is quite normal for this model. Too bad.
Wanna sell it?
Posted on Mar 19, 2010
Jogwheel Repair
Sounds like a ball bearing is gone! i'm sure london has a lot of deck repair shops and a general service should do it! spring went in my CDJ 1000's not so long ago and it wouldn't play at all in vinyl mode quick service did the trick
Apr 02, 2014 | Pioneer CDJ-1000 CD Player
Hey! my CDJ is playing and stopping, playing and stopping not in any sort of pattern either. almost like someone is touching the top plate in vinyl mode. it happens aswell if you try and slow down the...
Hi, if you mean the fault occurs in the cdj vinyl mode and your cd dosent play... then it sounds like your jog wheel sensor membrane. but would have to be checked firstly by an engineer.
if you live in the uk then you can send your pioneer cdj for repair to www.audiovisualservices.info
Hope this has helped you.
Feb 14, 2011 | Pioneer CDJ-1000 CD Player
My Pioneer CDJ 800 MK 2 - will not play in the vinyl mode, the cue button is flashing _ if i take it out of vinyl mode it will play fine , do i need to reset it?
Does the unit play in vinyl mode if you turn the platter by hand?. If this the case the commom fault in the "sheet switch" which is under the platter and sensors the pressure when you press the platter.
The "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it (i.e something is sat on it for a long time), it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
May 14, 2010 | Pioneer CDJ-800 Turntable
My jog wheel sticks / doesn't glide like it should...
I had the exact same problem. I was working a party when some drunk ******* spilled some beer in my coffin case, thus getting into the jog wheel and cue button. I continued to work with it for a few months but got pretty fed up and brought it to a pio dealer. They fixed it up quick and cheap, now it glides like my other mk3s. I'd say bring it in a get a quick quote.
Mar 31, 2010 | Pioneer CDJ-1000 CD Player
CD BACKSPIN
CD Mode does not react in the same manner as as Vinyl mode when you try to back spin. At the very least, you will only be able to go back a few bars. It's mainly used to set the Cue properly.
If you want it to back spin, you'll have to use the Vinyl mode.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 03, 2009 | Pioneer CDJ-800 Turntable
Vinyl mode does not work on my cd j mk2 1000, just cdj mode
if just bought take it bak and get another on may be a manufacturing problem.
Jul 01, 2009 | Pioneer CDJ-1000 CD Player
Turntable mode does not work
CHECK SENSOR & SENSOR SHEET UNIT DISPLAY UNIT
MAKE SURE NO LIQUID WAS DROPPED INTO UNIT
Mar 18, 2009 | Technics SL-DZ1200 CD Player
CDJ 800 wont play when in vinyl mode
Well im having the exact same problem and cant for the life of me figure out why it wont work if you have a soulution please please please email me
gasoline@live.co.uk
Aug 25, 2008 | Pioneer CDJ-800 Turntable
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Pioneer CDJ-800 Vinyl Mode Broken
This is a common issue. There is a faulty switch on the CDJ800s, which needs to be replaced. Unfortunately, this is not an easy fix, and will need to be serviced by a professional.
If your unit is under warranty, I suggest sending it off to Pioneer for repair. If you cannot find anyone locally, our company offers nationwide service.
DJPROAUDIO
TWEAK AV LAB
Jan 05, 2008 | Pioneer CDJ-800 Turntable
Panasonic Technics SL-DZ1200 Turntable Logo
211 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
