Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Problem with TV turning on and off sound remains on though
Is it very expensive to change a bulb in a big screen RCA and can I do it myself? model number M50WH92S
  • rnrae2006 Mar 01, 2009
    I understand that but I just want to change the bulb itself. I am going to keep the housing that surrounds the bulb. I found the bulb for a little over 100.00. Is is hard to rewire the bulb into the existing housing?
    President:
  • RCA Master
  • 1,779 Answers
Changing the lamp is easy enough. The lamp is about $250.00 . There's a lamp cover door usually in the back that removes, then the lamp housing will be displayed held in with 2 screws most of the time,, then you will be able to pull the lamp assembly out.
Posted on Feb 26, 2009
  • Jim Krause Mar 03, 2009
    No, not hard, after you expose the bulb be careful not to over tighten the nut on the neck of the bulb and do not touch the face of the bulb with your hands, the oil from your skin will prematurlly shorten it's life. It's straight forward.
Can I replace the bulb on my TV myself, or do I need a TV repairman?
The bulbs on projection tv's are typically designed to be replaced by the owner of the TV. They are a big pricey though. Do a good search online to try and get the best price. There will usually be instructions included with the replacement bulb. If not, visit RCS's website and download the manual. The unit that needs to be replace is typically located on the back of tv and secured with several screws. There will be a wiring harness to unplug and the unit will slide out. Just replace the bulb and reinstall the unit. Remember to NEVER touch the bulb itself with bare hands. Any oils from your skin can cause the bulb to prematurely burn up or even break immediatly when turned on.
Mar 02, 2011 | RCA Scenium M50WH187 50" HDTV
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
Changing Bulb In Big Screen
That model Sony doesnt have a bulb it has three picture tubes cost about 250 -300 each and need to be properly aligned when replaced
Mar 04, 2009 | Sony KP-53HS30 53" Rear Projection...
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
I HAVE A OLDER MODEL RCA HOME THEATER BIG SCREEN TV
Need model # more than likely you have no high voltage going to crt. It could be horizontal output and starter caps and much more. Is there any lights that stay on when pressing power?
Sep 10, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
257 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
