Question about HP Officejet 5610 All-In-One InkJet Printer
Displayed paper jam error after disassembling for dedustin
It was previosly displaying "cartridge carrier jam"
    Novelist:
  • 180 Answers
Dandeeco is right but try to check the cartridge part if it there are any loose parts..there are times that the strings inside the cartridge is loose or damage and it will cause that error. just keep posting what you see
Posted on Mar 10, 2009
    Problem Solver:
  • 12 Answers
Have had similar problems with my "Older" R-series R60 and the jam was usually accompanied by a "grinding" sound from the printer mechanism. I found to be the problem was the cartridge drive belt/home positioning have been misaligned by usually inadvertive moving of the cartridge either when changing cartridges or whatever may prevoke movement. My resolution by accident, was repositioning the cartridge a little bit in either direction. And power cycling the printer until I found the position "Sweet spot" when no grinding is heard as the printer finds its home position. Maybe this will work for your unit as well if you encounter it again. It beats dismantling and still having the problem, right?
Posted on Mar 07, 2009
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
How do I fix the unsupported cardridge message
The error can be caused by either a communication failure between the cartridges and the printer, a dirty contacts on the cartridge or the cartridge carrier, or a defective cartridge. Try removing the cartridges from the printer. Close the cover. Wipe the nozzles on the cartridges with a damp paper towel. Unplug the printer from the power source. Wait at least 30 seconds before replugging. When the printer's ready, reload the black cartridge then close the cover. If error displays, replace the black cartridge. If no error, reload the color cartridge. If error displays, replace the color cartridge. If you have already tried replacing both cartridges with new ones yet error displays, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks.
Aug 20, 2010 | Lexmark X2350 All-In-One InkJet Printer
Displays error 502
Error 502 means that the printer has stalled. Probably caused by the carrier getting stalled or a paper jam. Check of any paper jams or check inside the printer where the cartridges are. Make sure the cartridges are well-seated in the carrier. You can remove the cartridges and insert them back in. Check around the carrier for any foreign objects or any obstruction along its way.
Apr 02, 2010 | Lexmark X5150 All-In-One InkJet Printer
After paper jam printer displays error light and will not function
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
The printer error is Oxc18a0005 it said ink system failor. how can i solve it
Issue One of the following ink system error codes displays on the printer touch screen display: 0xc18xxxxx or 0xc19xxxxx . Solution Follow the steps below to resolve this issue.
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error codes still display on the front panel, service the printer.
Jan 28, 2010 | HP Photosmart D7260 Printer
MY CANON MP830 WILL DISPLAY A "ERROR 5100" USUALLY BEFORE OR AFTER PRINTING. IF I RESTART IT WILL PRINT ONCE, THEN DISPLAY "ERROR 5100." I CAN'T FIND ANY PAPER JAM IN PRINTER. HOPE YOU CAN HELP. RAY...
Other than:
1) checking that no paper is jammed in the printer (don't forget to check the rear access door for paper jammed internally)
2) holding the <On/Off> button until the display goes blank, then waiting ten seconds before pressing <On/Off> button again (to reset the unit) and
3) checking that the ink cartridges are properly installed,
if the problem persists, your Canon MP830 may require repair.
Dec 20, 2009 | Canon Office Equipment & Supplies
Problem after clearing paper jam paper jam message still being displayed no other programmes functioning cartridge carrier will not return to cartridge change position
Restart your computer and power-cycle your printer off and back on.
Make sure the paper tray is not overloaded.
Make sure the paper in the tray firmly pushed into the paper tray towards the printer.
Jun 28, 2009 | Lexmark P4350 All-In-One InkJet Printer
Paper is jammed,but there is no paper in the printer
first... off you printer and then pull the carrier until you reach the carrier of cartridge..and then replace the cartridge..
try to up it again..
May 13, 2009 | Canon PIXMA MP160 All-In-One Printer
Error #1203
Error #1203
A 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please carry out the steps below the image to confirm that this is a cartridge failure rather than a hardware problem
  1. Make sure the All-In-One is powered on.
  2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
  3. Pull the old cartridges towards you, and then lift them out.
  4. With the cartridges out of the printer, shut the access door and the control panel.
  5. Power the printer OFF and then back ON.
  6. Check the operator panel to see if the same error has returned or if a new message has appeared.
  7. If the message displayed is 1203, there is something wrong with the printer hardware.
    If the message now displaying is Cartridge Missing, do the following:
    1. Reinstall the cartridges into the printer.
    2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
    3. Push back firmly on the cartridges until they snap securely into place.
    4. Close the cartridge access door, and then close the control panel.
    5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
    6. With one cartridge in the carrier, close the access door and control panel.
    7. Check the operator panel. If the 1203 error is displayed, this cartridge is the defective item.
      If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
    8. Please replace the defective cartridge.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
HP Officejet 5610 All-In-One InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
