Question about Vizio L37 Television
My Vizio L37 is on with no picture
Also it will not shut off unless I unplug it. When I plug it back in I see the regular stand by light. I press on and the light changes to the on color. I will also see some light very faint on the screen. Nothing works, input, menu etc buttons. Then I must unplug for it to shut off?
  • 4 more comments
  • Anonymous Apr 06, 2009
    The power on indicator will change from amber to green when the power on button is pushed on either the remote or the side panel. No sound or light on the display and the only way to turn the power on indicator back off is to unplug it from the wall.
    I measuered the voltages on the power supply board and they are all good. What is your next guess?
  • Flat-Fenders Apr 06, 2009
    The power on indicator will change from amber to green when the power on button is pushed on either the remote control or the side panel. There is no sound or any change in the display (it remains dark) and the only way to extinguish the power on indicator is to pull the AC plug from the wall.
    I measured the voltages on the power supply board and they are all good. What is your next guess?
  • DBR79 Apr 11, 2009
    Same issue; its on, but nothing works and I have to unplug it in order to turn it off. The TV is less than two years old. If this is a recurring problem with this product then I definitely will not invest in Vizio again.
  • Anonymous Apr 25, 2009
    Exactly the same problem - TV is less than 2 years old. I was on the phone with Vizio, they were no help
  • jcella May 02, 2009
    Vizio is garbage. Luckily for me I bought mine at Costco which extends the warranty one year. They were very helpful to get Vizio to send someone to come out and fix it. I could tell Vizio didn't want to and tried all they could to delay fixing it but thanks to Costco they did. They replaced the power supply and mother board and now it works fine. Less than 2 years old these things should not go. I will never buy from Vizio again as not only does there product stink but their lack of customer service is worse. Buyer beware.....
  • Anonymous May 06, 2009
    vizio black screen
    President:
  • Vizio Master
  • 1,779 Answers
Most likely a defective power supply module which can be repaired to component level. A local svc co. would be your best bet now.
Posted on Feb 26, 2009
My picture went away and has been replaced with
Can it be fixed? likely yes. Is it economical to fix? Probably not. TV technicians are a dying breed due to outsourcing and component availability (China). Unless the failed component can be had used and labor is cheap you are likely best to buy a new TV. TV's these days are consumable goods like most everything else.
Mar 20, 2010 | Vizio L37 Television
Need to replace power supply to vizio l37 hdtv, difficulty level?
simple. take the stand out first, then the surrounding screws on back cover. Remove back cover and the power supply is just right there. Make sure you wear ESD or you may short out the fuse.
Jun 04, 2009 | Vizio L37 Television
Picture but no sound on my Vizio L37 Flat Screen
I had the same thing just happen and I used the following instructions from the Vizio Website for "humming sound" on tv and it worked. My sound is now working!!!!
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on.
Reset the TV settings.
Jan 29, 2009 | Vizio GV42L 42 in. LCD Television
Vizio TV (L37) will power up but no picture
The backlight is powered by its own supply (although it may receive input from the main supply) and it sounds like the main supply or one of its outputs has failed disabling the video and sound processing.
Dec 24, 2008 | Vizio L37 Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
L37 tv turns off on own and then will not turn back on
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Jan 31, 2008 | Vizio L37 Television
Sound of My Vizio L37
I know thier are some hidden sound settings in the menu if you hit your menu key on your remote [or the one on the side of your tv],then goto to the tv and press both the channel up and down buttons simultaneously. You will see a factor menu, try changing the sound settings in there.
Aug 16, 2007 | Vizio L37 Television
Vizio L37 Television Logo
206 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
