Question about LRD6599SWS Radar Detector
Need replacement bracket
Need the windshield mounting bracket with suction cups,
for the LRD6599SWS.
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 86 Answers
SOURCE: Need new suction cup clip
CALL THEM AND TELL THEM IT BROKE AND 9 TIMES OUT OF 10 THEY WILL SEND YOU A FREE REPLACEMENT...
Posted on Apr 28, 2009
I need instructions on how to mount the nuvi 200w to my windshield
To secure the nuvi 200w to your windshield with the included suction cup mount (pictured below),
center the GPS on the clip, and tip the bottom edge on the bracket. Push the top of the GPS against the top clip until it clicks into place. Hold the bracket and GPS near the windshield where you like it best. Note where the suction cup is on the windshield in relation to the mirror, etc. Remove the GPS from the mount's clip by pushing the top tab back from the top of the GPS.
Clean the windshield (or portion that the suction cup will be stuck against) with a paper towel or newspaper and ammonia solution like Windex, etc. Clean the suction cup with the paper towel and Windex, too.
Lift the lever at the base of the mount - is shown in the picture above - if it isn't already. With the mount oriented as shown in the picture above, press the suction cup against the windshield where desired with one hand. Hold the mount firmly against the glass and use your other hand to press the lever on the base back toward the suction cup and glass. Press until it lays flat against the base / suction cup. Plug the power cord into the GPS and reinstall the GPS in the mount clips as done earlier.
To remove from the windshield, release the GPS from the mount clips, and lift the lever away from the base / suction cup. Locate the tab that is connected to the suction cup edge near the lever. Pull on the tab away from the glass to break the suction seal and remove from the windshield.
If this was helpful, please rate it 4 thumbs up. Thanks & good luck!
Sep 20, 2011 | Garmin GPS
My garmin nuvi 350 suction mount falls from the windshield after several days.
I believe they all do that, I own a Garmin and I bought what looks like a bean bag because I got tired of my suction cup mount falling off my windshield. The nice thing about the bean bag mount is that you can move it closer to you and place it anywhere on your dash. I bought mine on ebay from the Mount Guys they have a big selection of mounts for all types of GPS's take a look you might want to make the change too.
I hope this helps you out and if it did please leave me some feedback
Apr 03, 2011 | Garmin GPS
Mounting of gps can't mount on windsheild.
Tomtom GPS devices come with a variety of windshield suction mounts. All have in common that the windshield and the suction cup both must be clean; use a mild soap dispersed in some warm water to remove any dirt. Rinse properly. Sometimes it helps to keep the cup a little moist.
Make sure the cup is not warped due to previous exposure to heat, and check for any nicks in the rubber. Small damage may easily make the mount unusable and you'd need to get a replacement.
Models with a lever mechanic: open the lever (cup becomes flat), press the cup against the windshield and while keeping pressure, close the lever. It will lift the middle of the cup away from the windshield, causing a vacuum.
Models with a ring around the cup base: Turn the ring all the way counter-clockwise (cup becomes flat), press cup against windshield and while keeping pressure, turn the ring clockwise 90 degrees. This requires some force, but in my experience these mounts stick more reliable,
Jan 04, 2011 | Tomtom ONE XL GPS
WIll not adhere to the windshield... suction cup does not hold GPS
Dec 31, 2010 | Tomtom GPS
How exactly do i fix the suction back onto the windscreen please? I have just bought a tomtom and don't understand the drawings!
Dec 31, 2010 | Tomtom ONE GPS Receiver
How do I attach my garmin to my dash mount?
The Garmin Nuvi 255w comes with a three piece dash mounting kit. A round disk smooth on one side tape on the other to affix to the dash (most dashes ar textured and the suction cup will not hold to textures) a suction cup arm with a ball end, and a bracket with a receiver for the ball. Snap the bracket and arm together, this can take a little effort. mount the disk to your dash in a place that doesn't obstruct your view of the road. then place the arm/bracket on the disk and push the lever down creating suction to hold the mount to the dash.
Another option it the beanbag dash mounts that hold the arm without sticking to your dash.
If this answered your question please check +. If not please elaborate on your queston
Apr 26, 2010 | Garmin nuvi 255W GPS Receiver
Mount no longer sticks to windshield
Well a new mount suction cup will need to be purchased. you can grab one at radioshack.com you alsmo might want to wet the plunger then try to stick it. Or clean of that dirty windshield and try again.
2 solutions
1. clean the windshield and apply a little water to the back of it.
2. Buy a new suction cup.
thats all I hope you to stop by and rate it thanks.
Apr 16, 2010 | Tomtom ONE GPS Receiver
We installed the car cradle to the windshield but receiver won't adhere to the disk. Please tell us what we did wrong. Thanks, Pat skillman
i think you mean the mount wont adhere to the disk..normally the disk is not used to mount the gps to the windshield, is more for the dash area or another spot where the suction cup wont adhere. the are rare occasions where the disk is needed for the windshield though, but its rare. try ataching it to the windshield without the disk. lift lever at suction cup, press the mount firmly against the windshield, then press the locking lever down to secure the mount. the picture below is the wount in the unlocked position.
form Magellan
This adhesive disk provides an alternative to mounting your Magellan GPS to the windshield of your vehicle. The disk adheres firmly to your dashboard or virtually any surface. Then attach the suction cup of your windshield mount to the disk.
Aug 14, 2009 | Magellan Roadmate 1200 Car GPS Receiver
There is a black disc but I do not see any instructions for using it.Does it mount on the windshield?
my Magellen came with a black disk with adhesive on 1 side. Intended to be adhered to any smooth surface (e.g., windshield). The mount for my unit includes a suction cup. So, mount black disk to windshield and attach suction cup to smooth side of black disk. Be sure disk is positioned where suction cup and bracket and GPS will have sufficient room to mount everything.
Jun 05, 2009 | Garmin nuvi 255W GPS Receiver
LG GPS not suctioning to windhield
You must clean the window area using windex, or other cleaner, and wipe until dry. A clean winshield area provides the best suction, from the mounting bracket.
Slide the mounting bracket switch to Off & On a few times, make sure the suction cup is able to move(slightly) and that the small tap is facing the area with the notch in the metal.
After putting the switch to the middle, moisten the suction cup slightly
(saliva works bestter than water for some reason)
press it to the window with a slight amount of pressure
then move the switch, (Which should be set to Center!)
to lock it on firmly.
If this doesn't work, then there is a good chance the suction cup has become hardened by the sun. If that is the situation, you'll have to contact LG
(or a place that sells "knock off" brackets to get a replacement.)
I never leave my LG GPS in the car, when not in use. Even the bracket comes out, as I've seen what the sun can do to damage those plastic suction cups, fortunately, I learned it on a $5 replacement set for a Radar detector/Emergency Vehicle Alert device, and not a more expensive bracket.
Dec 07, 2008 | LG LN740 GPS
LRD6599SWS Radar Detector Logo
48 people viewed this question
Top Uniden Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you an Uniden Vehicle Part and Accessory Expert? Answer questions, earn points and help others
