Question about Vulcan 481FL Gas Kitchen Range
Oven will not turn on even though the pilot is lit vulcan 481fl
Morning,i recently had a fire supression inspection on our vulcan 481 FL range. when they relit the pilots the burners on the top fired up but the oven does not. got any ideas on why or how to fix this.thanx,cyndi lu
3 Suggested Answers
Treefrog15
  • 127 Answers
SOURCE: One of the top burner pilot lights will not stay
You probably have grease that has gotten into the pilot. Turn off the gas to the pilot and detach the pilot tubing and pilot tip. It sometimes helps to take a propane torch and heat up the pilot tip and tubing, paying special attention to the first bend from the pilot tip. Get it red hot and tap out any ash from the inside. You may have to **** out the tubing with a piece of bare wire or blow it out with WD-40. With the oven pilot, check the pilot flame. If low, adjust. If OK, replace the thermocouple. If neither of these corrects the problem, replace the pilot satety. I always recommend a new thermocouple with a new pilot safety.
Posted on Feb 25, 2010
  • 439 Answers
SOURCE: Vulcan A1990 Model 60XL;
You need to replace the thermocouple for both sides of the oven. That is the most common issue with pilot lights and gas burners. The safety shut off will engage when it does not sense any heat, ie: thermocouples.
Posted on Sep 08, 2010
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Feb 23, 2010 | Vulcan Kitchen Ranges
Hotpoint gas range model RGB508 pilot is lit but oven burner don
are we talking about the oven.if so and the ignitor lite's up,and look's as strong as it was,than you my have a BAD SAFTY VALVE.
Nov 26, 2009 | Ovens
Where is the oven pilot light ?
Most modern ranges don't use pilot lights at all; if your burners are lit by high voltage spark, the oven will use either that or a 'surface igniter' to turn on the oven. Even though pilot lights don't use much, they still use some and this would add to your bill (if you have one-we have free gas).
Oct 07, 2009 | Whirlpool SF357 Gas Kitchen Range
How do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
May 13, 2009 | Kitchen Ranges
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven pilot light will not stay lit
The thermocouple is bad this is the probe that sits next to the pilot,the pilot flame heats the thermocouple and then it sends a micro voltage to the valve to keep it lit.Goto hobartcorp.com and find your model then the part number.
Sep 04, 2008 | Vulcan 60L Gas Kitchen Range
What could be causing this?
i service these ovens alot and my first guess the t-couple you already replaced.i wouldnt think its the valve.lp burns very dirty as you know,clean out the burner/pilot assmbely and see if this solves it.also take a look at it when its lit and see if the pilot is being pulled to the burner.let me know.also if the unit has a regulator on the back pull the vent plug and clean it up.
Nov 09, 2007 | Vulcan 36L Gas Kitchen Range
Vulcan 481FL Gas Kitchen Range Logo
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
