Question about Logitech Cordless Mouse
V220 Mouse. Which way does battery positive terminal go?
Does the battery positive terminal point toward the wheel on the top or does positive battery terminal point toward mouse tail(if cordless mouse had a tail).?
    President:
  • 2,976 Answers
A button cell looks exactly opposite of a regular battery. The small button end is negative.
Posted on Feb 28, 2009
Replace battery 2007 Tahoe 5.3 v8 4wd. Thanks
{: ) You need to remove the four(#13mm) bolts of that elbow brace just above the battery.
Remove the battery retainer bolt (#13mm) located on its base, the side facing the engine.
Loosen the battery terminals (negative terminal first) and pull them aside towards the engine so it will not interfere with the battery removal.
Try to raise the battery on the positive terminal side to an angle of about 60deg and slide a little bit towards the coolant reservoir so you could gain a better leverage when you pull it up. Doesn't matter if at some point the battery went 90 degrees. Just pull it fast and swiftly. Careful with your fingers. The battery is quite heavy and you may be thrown off balance while trying to pull it out.
You may rest the battery on top the coolant reservoir if needed, buit only for a short while to regain your momentum.
Installation is just the reversal. The battery connection will be to install the positive cable first. .
Jun 17, 2011 | 2007 Chevrolet Tahoe
I have the v220 it jumps while i am pointing & does it's own thing!!! i have changed the batteries... can i use a corded mouse if i turn the cordless off???
It sounds like your receiver isn't close enough to your mouse. Try moving the receiver and mouse closer together. If that doesn't make it any better, then you can certainly use a corded mouse.
Jul 19, 2010 | Logitech Cordless Mouse
ZOOM FUNTION ON V220 MOUSE
I'M ANSWERING MY OWN QUESTION: PRESS LEFT CLICKER AND HOLD, WAIT FOR MAGNIFYING GLASS TO APPEAR, THAN SCROLL WHEEL UP AND DOWN FOR ZOOM IN AND OUT. IT IS COOL! I LOVE IT WHEN I FIGURED THINGS OUT ON MY OWN.
Feb 18, 2010 | Logitech V220 Mouse
V220 worked for years. Just quit. Replaced battery, went through mouse reset procedure & download. Still does not work, battery is good.
Seems that removing the laptop battery & getting a simple reboot, was all it needed. Thanks for the quick responses from you.
Feb 15, 2010 | Logitech V220 Cordless Optical Notebook...
My logitech V220 optical mouse won't work, I changed the batteries.
Hi three, uninstall the Logitech V220 Cordless optical mouse driver from the laptop and then restart the laptop again. Now install that Logitech V220 Cordless optical mouse driver again . I am sure its will start working. If not then make sure your batter Is properly fixed inside in the mouse & that's fully charged. After those thing if still not working then visit service center, because the mouse censer stop working and its damaged.
Thanks & waiting for your feedback.
Feb 09, 2010 | Logitech V220 Cordless Optical Notebook...
My mouse isnt responding at all. the weird thing is, when i put the battery in, the light doesnt turn on
you need to press the reset switch ont he recever that connect to the computer and then the mouse so it can sink up.
Dec 04, 2009 | Logitech V220 Mouse
Reset cordless mouse to use on laptop .
batteries and the small reset button under mouse?
May 01, 2009 | Logitech V220 Wireless/Cordless Notebook...
Logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Mar 01, 2009 | Logitech Cordless Mouse
Logitech cordless V220 Battery compartment - can not open.
push on the little button at the bottom of the mouse and slide the top bottom half of the cover toward you. The mouse require 1-AA.
negative of the battery towards the left click button.
Jan 30, 2009 | Logitech Cordless Mouse
Cordless v220
Take a look at this web site. Just click the link:
http://www.logitech.com/index.cfm/mice_pointers/mice/devices/3295&cl=us,en
Your battery may be dead.
Software for your mouse listed at this link:
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en?selectedcrid=398&selectedcid=146
I do not have your v220 mouse so I'm unsure if you can replace it with a standard battery. Check it or exchange it from where you bought it.
Good Luck & kind Regards.
& please vote.
Feb 23, 2008 | Logitech Cordless Mouse
Logitech Cordless Mouse Logo
87 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
