Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
GE Monogram Built-in ZISB48DYB water leakage from top of freezer
Water is leaking from top of freezer and freezing on sides and racks.
The evaporator drain line (clear plastic hose from evaporator section to condenser section) is dry which seems to indicate that the drain is blocked.
How do you access the evaporator section to allow for clearing of the drain line?
  • wlanghorst May 12, 2009
    Same problem. Water leaking from above the ice maker section, freezing on sides and freezing cubes together.
SOURCE: fridge autodefrosting but condensation not
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Posted on Feb 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
  • 146 Answers
SOURCE: getting at a clogged drain in evaporator compartment
There is a panel over the evap. in back of the freezer section. Remove it and you will see the drain at the bottom of the freezer below the evap.. You will see a little tray with a hole in the center of it. You will need to clean out this tray and run a wire down through it to clean out the tube that runs to your drain pan. Don't use a coat hanger or anything too stiff as it may puncture or pop the hose off. It has to be something flexible but strong. That should do it!
Good Luck!
God Bless
Posted on Dec 26, 2007
heatman101
  • 43501 Answers
SOURCE: GE ZISB48DYB freezer side is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
  • 441 Answers
SOURCE: Does the ge monogram zisb48dyb
the filter on that unit is behind the panel ontop, it will be on the righthand side
Posted on Nov 27, 2010
Ice in freezer and warm refrigerator Zisb48dyb
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
Mar 31, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
GE Monogram side by side built in model # ZISB48DYB. Freezer side ice cold but the refrigerator side is very warm/ hot no cold at all
Check to see if your fan is running, if its running your more than likely have a damper issue. check the damper on the top of the fridge and see if air is coming through. if not you need to replace or repair the damper.
Aug 05, 2013 | General Refrigerators
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
Does the ge monogram zisb48dyb have a replaceable water filter? If so where?
Nov 27, 2010 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
GE Monogram fridge is not dispensing water. Ice maker is working fine. Not a water filter issue. thanks -
Water and ice solenoid valve is one valve with two coils and exits.
The most posible case is the water side is coggled or coil broken and need to bee clean or a new valve
Oct 16, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
GE ZISB48DYB freezer side is leaking causing freezing on sides and racks. Could this be avap line?
heatman101
Sep 03, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
484 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
