Question about HP DeskJet 880c InkJet Printer
I have put a new colour cartridge in the printer but the colour is just pink. How do I check on my ink levels and how do I clean the printer head and nozzles?
  • Anonymous Apr 02, 2009
    I have the same problem. Wish I could help :-(
  • Anonymous Apr 06, 2009
    printer color became bland or pink with no regular color. I changed the cartridge and it did not fix. I tried a second cartridge but still no luck. James
I had the same problem on mine. Just replace cartridges until you get a good one. Cartridges with dates as late as 2007 have been bad for me. Unused cartridge can still be bad.
Posted on Jun 29, 2009
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
My printer is printing in pink. I have installed a new colour cartridge but the problem exists. Can you help
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Aug 09, 2011 | HP DeskJet D1460 InkJet Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Just chaned ink cartridge and every thing printed out pink clean the pink and now nothing is printing tried cleaning the head and did the nozzle check and still not printing
It seems to me, if you have changed your colour cartridge that is, that you do not have enough black ink in your black ink cartridge, so you should change this also.
Barbara Grey
Oct 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
When I print out picture, pictur came out so many pink stripe across the picture.
There probably is nothing wrong with your PINK ink-cartridge.
It's one (or two) of the other colour ink-cartridges that either are EMPTY or having CLOGGED ink-jet mechanisms.
Run a "print-head-cleaning" cycle.
Aug 27, 2010 | Epson Stylus 1400 InkJet Photo Printer
Printer wont print the right colour
You might have selected the wrong profile for your preferences. Go to printer properties and select defaults for all. This will solve your problem. If still facing problem comment back.
Sep 07, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Colour ink failing
Remove the ink cartridges and clean the sensor below them.
Possibly ink on the blocking the sensor from reading the poper ink level.
After that put the cartridges back in and then go to printers on your PC and right-click the printer on the screen and try to locate a cleaning process or if you have software installed for the printer, run it through there.
Do it a few times if need be and then check the ink level.
Head cleaning it's normally called.
If it doesn't work, then the printer might simply need replacing.
Jul 23, 2009 | Epson Stylus 830U InkJet Photo Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Oct 16, 2007 | Epson RX620 All-In-One InkJet Photo...
HP DeskJet 880c InkJet Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
