Question about Hitachi P50S602 50 in. Plasma TV
Best solution to integrate Hitachi P50S602 into my B&K preamp
I've got a B&K preamp that it's by now about 8 years old (don't have the model # on hand) but I know for sure that while it accepts optical and coax digital inputs, for sound, it's not ready for any HDMI imputing. It's got a pass through video that could accommodate either of S-VHS, Composite, or Component video. Now that I'm expecting this Hitachi plasma panel, in order to benefit from the HDMI, how do you suggest I best connect the sound into the B&K? Should I go HDMI into the Panel first and then output sound from the panel into the B&K afterwards?
    President:
  • 2,992 Answers
Without an HDMI input on the B&K, your best and probably only solution would be to run all the sources to the Hitachi TV, and go from the Hitachi audio output jacks to an available input on the B&K. Then do all your source switching on the TV. It may not be the best sound, but you gotta work with what you have.
Posted on Feb 26, 2009
  • 257 Answers
Hi, That is the best way. That connection allows you to take advantage of the panels audio features like sound leveling. The panel has a digital audio output(optical)which is good. By passing the video with the HDMI is the right thing also, the less connections in HD the less loss. You made the right choice ya Fixya yaself!
I've had my Hitachi 55" model #55VG825 TV for
As it is 7 years old, replace all the electrolytic capacitors at its main power regulator board. All of them might have value deteriated. If so, power supply wont get proper regulation. If you wish to get more details, check this link.
Apr 22, 2013 | Televison & Video
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
Jul 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
I have an 8 year old Friedrich model SS10J10AR unit. The unit keeps shutting off when in cooling mode. When I leave it in FAN only it runs. I tried to reset the circuit board by hitting "Money...
Honestly, repairing and 8 year old AC unit (assuming parts are still available) can cost almost as much as buying a new one. If this is the first time you've had a real problem with it ... You've gotten your monies worth over the past 8 years. But, the decision is yours to make.
Thanks for choosing FixYa.
Aug 10, 2011 | Friedrich QuietMaster Electric SS10J10AR...
Does this motherboard have integrated video? Or do I need to buy graphics card?
Well if your computer is new generation computer than it has integrated video and you don't need to buy graphics card to view normal display.Now a Days all the new motherboard has integrated 128mb to 256mb graphic chipset in build , but if you want to play high resolution games and graphic works .
And if your computer belongs to old age,say 8-10 years old than you need to put a PCI VGA card to get normal display.
All the best.
Jul 11, 2011 | GE WBSR3140DW Top Load Washer
MY 50 inch Hitachi TV wont turn on and the on/off blue light at the bottom of the TV blinks 3 times then pauses and blinks another 3 times. This is non stop. The TV model # is P505601
Unfortunately, this indicates a technical fault with the TV which can only be fixed by a service engineer.
If the light is blue and blinks 3 times, it is indicating a fault with one (or both) of 2 circuit boards inside. They are the XSUS or YSUS boards and will possibly need replacing.
At least knowing this might help you ascertain a quote as too how much the repair will cost.
Jun 09, 2011 | Hitachi P50S602 50 in. Plasma TV
I have a hitachi p50s602 that flashes a blue light code 6 times. any idea what it is calling out?
no power / dead unit / comes on and protects itself, power led may blink in 3 or 4 times cycles.
check/confirm sdr buffer ics are not shorted, if so, replace affected sdr pwb. The buffer ic are on the side of you set in the back once it's removed(cover).
Mar 09, 2011 | Hitachi P50S602 50 in. Plasma TV
We have a Hitachi Model RAS-63CHA2 that we need to find out how old the unit is as it has broken down. Can anyone tell me when these models were first produced?
This model was produced approx 6-8 years ago a common problem is the compressor capacitor 50uf. I must of changed 50 of them by now.
Jan 19, 2011 | Hitachi RAS-09UH Air Conditioner
Tv shuts off after a few minutes
I bumped the antenna cable to my Hitachi plasma P50S602 model and where purchased partio.Mi warranty tells me not to cover it. Ask for a technician and the cost is like buying a new plasma and I can fix it?
Apr 10, 2010 | RCA HD52W56 52" Rear Projection HDTV
I got new power supply for my tv and still doing same thing, blue lite stays on only way to turn of is up plug it its a hitachi 50s601 plasma little more then 1 yr old, i talk to a tech and he maybe a...
blue light on is a good indication that the power supply is up not always but not replanding to commands is always the main board the cpu and commands are not talking
Nov 30, 2009 | Hitachi P50S602 50 in. Plasma TV
Age of tv?
I purchased mine from Circuit city back in spring of 2002 as a display model that they were no longer selling. So I would assume 2001 which would be almost 8 years old. Excellent tv!
Nov 03, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi P50S602 50 in. Plasma TV Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
