Question about Jet 3 Ultra Power Chair
WHAT MAKES THE CHAIR NOT MOVE WHEN CHARGING?
I WANT TO MAKE THE CHAIR SOLAR POWER . BUT THE CHAIR HAS
A SAFETY SWITCH WHEN CHARGING THAT WON'T LET IT MOVE. HOW DO I MAKE IT MOVE WHILE CHARGING?
  • kdunbar36 May 11, 2010
    All chairs are different, I would have to know your Chair Name, but you could also call the company for which your chair was made from if its Quatum- it would be Quatum Rehab, or if you got the chair thru a Specialist, ask the specialist what makes it not move while charging it, They might be able to help, if you explain what you wnat to do. I've never heard of a Solar Powered Wheelchair with a standard wheelchair, only ones that have been built that way.
    Problem Solver:
  • 11 Answers
You cannot make a powerchair operate while it is charging. For safety purposes the power cuts out when charging batts. The only power is going to the batteries.
Posted on Mar 30, 2009
Travelux powerchair. How do I change the height of the seat
Hi:
The Travelux power chair seat raises and lowers with the height adjust switch. The switch will only work if the chair is stationary, and the chair will only move if the seat is lowered all the way , for safety reasons
Nov 02, 2017 | Motorcycles
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Are solar chargers expensive?
Not at all, pls check this one: Amazon com MASKELENA Solar Charger Solar Power Bank 12000mAh External... No more than $30
Oct 14, 2013 | Electronics - Others
My vision sport power chair won't move. the
says here thats a right motor fault, check the right motor connections and cableing
Sep 02, 2013 | Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Jet 3 Ultra Power Chair Logo
229 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
