Question about HP Scanjet G4050 Flatbed Scanner
SCANNER DISPLAYING ERROR MESSAGE WHEN TRYING TO SCAN NEGATIVES
THE MESSAGE THAT COMES UP SAYS "REMOVE TMA LID TO EXPOSE THE BULB." SINCE I HAVE ALREADY DONE THIS, I AM A LITTLE LOST AT THIS POINT.
    Scholar:
  • 85 Answers
The problem can be either of this two 1)the bulb is gone weak. 2)the motor which moves the bulb is gone weak.
and the third and the final thing its very difficult to to manually in this case still have a look. as the rays from the bulb passes from a lens that makes a proper ray.that should be very perfect but if you have removed the bulb and reinserted that that allignment of the passing ray will have moved from its orignal position.
Posted on Feb 26, 2009
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
I have connected the TMA to my hp scanjet and I have put a slide in it, but when I scan it, all I get is a scan of the whole glass and the slide is black.
When scanning slides and negatives the scanner lid lights up so light passes through the slides and negatives and the image is picked up by the sensor.
If the image of the whole glass is black then most likely the lamp in the lid is faulty.
Aug 19, 2011 | HP Scanjet 4570 Flatbed Scanner
When I scan a negative, all I get is a picture of this negative which is useless. I thought that I could get the picture out of the negative that I scanned and save it so that I could get rid of the...
With the scanner you should have received a cd "HP Scanjet 4800 Series HP IMage Zone Software. Mine is version 5.3 for Windows/8.4 for Mac OS v 10.2.
I have this installed on a pc.
When the button on the lid (2nd from left ) is pressed this opens a window HP Scanning.
On this is an option to "Scan Negatives using the TMA (Transparent Materials Adaptor)" Select this and follow any further instructions concerning optons.
Jan 20, 2011 | HP ScanJet 4850 Flatbed Scanner
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Can't scan PLEASE HELP!
SOLUTION: Download the latest version (v 7.7.2) of the HP software from the HP website at www.hp.com. Uninstall the previous software and then reinstall the downloaded software. WORKAROUND: Follow the steps below:
  1. Load the slides or negatives in the TMA and place it on the scanner glass.
  2. Open Image Zone and click on Scan Picture to scan everything.
  3. After the scan is completed, change the settings from glass to scan slide/negative from TMA. The unit will scan again and show the four slides or negatives in the preview.
  4. Click on the first picture in the scan preview and make the following changes:
    • change the dust and scratch removal/sharpness to none
    • change the resolution to 72 dpi
  5. Click on the second picture in the scan preview and make the same changes described above.
  6. Click on the third picture and then the fourth picture and make the same changes.
  7. Click Accept . The correctly scanned slide or negative images will be saved in the Gallery.
May 21, 2009 | HP Photosmart 3310 All-In-One InkJet...
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Where do i put the negative to scan on hp g3010 scanner
On the lid there are thin plastic rails that frame two 35mm Negatives. Place the film in that holder, framing what you wish.
Check HP's site for the owners manual for advanced settings for your specific model to get the best results from your Negative or as HP calls it Transparent Materials Adapter (TMA)
Let us know
Good luck
Apr 14, 2009 | HP Scanjet™ G3010 Flatbed Scanner
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
BROTHER MFC-8840D "Check Scan Lock" error message
I had the same problem. It means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This may fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remover the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable be carefull not to drop the lid, break the cable or the glass bed. After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp farther into the scanning area and repeat. Good Luck
Oct 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
HP Scanjet G4050 Flatbed Scanner Logo
381 people viewed this question
Ben Johnson
