Question about Logitech Z-540 Speaker
My computer speaker sound is not clear although the speakers are fine i think the problem is in volume settings help
  • 1 more comment
  • Anonymous Mar 31, 2009
    my computer speaker sound is not clear although
  • kevinjohn14 Apr 23, 2009
    i have a 2.1 i ball computer speaker and the sound is not clear. Is that problem of my computer or of the sound settings.
  • Anonymous Apr 29, 2009
    speakers sound fuzzy
SOURCE: my right speaker does not work
My left speaker didn't work, I described how I fixed it here: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Posted on Aug 14, 2007
Open SKy
  • 620 Answers
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
SOURCE: Speakers not working correctly
you need to activate speaker fill i the settings
Posted on Jun 19, 2008
  • 38 Answers
SOURCE: Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Posted on Jul 17, 2008
SOURCE: Logitech X-240 Speaker Volume Problem!?!?
you probably have it plugged into the wrong jack
Posted on Aug 16, 2008
Speakers don't work
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps W7
Sep 19, 2012 | Audio Players & Recorders
No sound through laptop
reinstall drivers
the speaker plug/outlets laptop on the side
hope this helps
Aug 05, 2012 | Medion Brand 12.1 WXGA Matte Laptop...
Can't get sound out of my speakers although sound registers as playing
Check that your computer isn't muted and the volume on the speakers is up. Check that the plug for the speakers is connected correctly. Check to see if the sound card that the speakers are plugged into is set as the default in the control panel. Is there any sound coming out of the front port (earphones). Try another set of speakers.
Jun 06, 2012 | Computers & Internet
My speakers are not giving sound although they are turned on
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 26, 2011 | Altec Lansing 120i Computer Speakers
Suddenly, my speakers won't make any sound. this morning they worked perfectly, and i've checked the input is fine (it works well when i plug headphones in the volume control) and if i plug my ipod, still...
if you are having problems with your sound
also
hope this helps
Apr 01, 2011 | Creative Labs I-Trigue 3220 Computer...
I bought this unit over 1 year ago, lately tried playing music but no sound came out of the unit, although power is on. No elctronic shop nearby to get assistance.
also
hope this helps
Mar 19, 2011 | Logitech X-230 Computer Speakers
Havebx1120 speakers from older computer wont work on new computer think it is the driver please help
also
hope this helps don
Mar 15, 2011 | Altec Lansing 221 Computer Speakers
My toshiba nb305 the speaker can't loud although volume100%
also
hope this helps
don
Mar 06, 2011 | Toshiba (P000352160) Computer Speakers
No sound
What do you mean that you had the computer's memory cleared? Was it reformated?
Aug 04, 2008 | HP Compaq JBL Pro (401508-001) Computer...
Popping in left speaker only...
just go master volume control and check whether the left and right speaker sound is in balance that is balance must be in middle... i think this audio property may have be changed
Jan 05, 2008 | Logitech Z-2300 Computer Speakers
Logitech Z-540 Speaker Logo
845 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
