Question about IBM Lenovo ThinkPad T61 Notebook
Microsoft Visual C++
When I open any .pdf file, a message receive that " Adobe Updater has stopped working", after few seconds options displays Debug or Close program", I click on Debug then 3 options displays "Check for solutions online, Run program or Close", I click on "Chck for solutions online". Problem Reports and Solutions window opens, when I click on "Microsoft" option a web page opens and on this page displays:
Page Not Found We're sorry, but the page you requested could not be found. Please check your typing and try again, or use the search options on this page.
Every time when I open .pdf file, this problem creats. Pl. give me solution.
  • AY Anand Feb 27, 2009
    I am very thankful to The FixYa Team for solving problem.
  • 447 Answers
You should download and reinstall Adobe Reader first to see if that solves your problem. Post your results back here.
Posted on Feb 26, 2009
  • John Elliott
    John Elliott Feb 27, 2009
    Glad we could help, let's go ahead and close this one with a FixYa.
PDF file corrupt, how to repair it?
There is a universal solution of your problem: PDF Repair Toolbox - The tool reads corrupted PDF files and saves all recovered information to a new file for Adobe Reader/Adobe Acrobat.
Mar 19, 2016 | Microsoft Office Professional 2007 Full...
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
How do I change Microsoft Reader as default?
http://www.microsoft.com/reader/info/tips/nolonger.aspx
Here's how to fix the problem:
  1. Shut down Microsoft Reader:
    a. From the Start Menu, tap "Settings"
    b. Select the System tab.
    c. Select the Memory icon.
    d. Tap the Running Program tab.
    e. Highlight Microsoft Reader on the Running Program list.
    f. Tap the Stop button.
  2. Tap OK.
  3. Start File Explorer
  4. Navigate to My Documents/Annotations
  5. Select and delete the .EBO file for the problem title. The correct .EBO file is the file that begins with the eBook title. If more than one .EBO file exists for the problem title, select and delete each one.
  6. Start Microsoft Reader again.
  7. Open the eBook. Let the device remain turned on, allowing Microsoft Reader to repaginate until it completes. This process should not take more than a few minutes. Microsoft Reader needs to perform this operation just once for each eBook.
How do I know if Reader is still handling background pagination on the title?
  1. Open the eBook in question.
  2. Begin reading the content.
  3. On the bottom of the Reader page, tap and hold the page number for a couple of seconds — then release it. The Riffle Control should be displayed: its appearance may take a second or two.
  4. The Riffle Control shows you where you are in the eBook. The leftmost number is the first page of the eBook; the rightmost number is the last page of the eBook. If the rightmost number is displayed in red, Microsoft Reader is not done with background pagination. If the rightmost number is displayed in black, Reader has completed pagination.
Jul 26, 2010 | Adobe Computers & Internet
I open a link with word document and I get code execution has been interrupted, and it asks me if I want to debug, stop, clear, and click next on the pop up display.
If this occurs in specific link, the problem must be parametric. Or if it appears in all the link, you should reinstall the word document again and if the problem does not resolve, remove Microsoft Visual Basic Enterprise completely and then check. If it is opening correctly, then reinstall Microsoft Visual Basic Enterprise. If problem appreas again, there must be something fishy in your Visual Basic disk.
Nov 18, 2009 | Microsoft Visual Basic Enterprise Edition...
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
I downloaded updates and now I'm getting "runtime error" messages
Turn off the Machine Debug Manager Service. It is only needed if you are debugging Visual Basic software.
To do so:
  1. Click START, select RUN
  2. Type "Services.msc"
  3. When the Management Console opens, search for "Machine Debug Manager" on the right hand panel and doubleclick on it to open it's property sheet
  4. On the property sheet, on the "Service Status",click "STOP". On the "Startup type:" select Disable (or Manual)
  5. Close the Property sheet; Exit the Management Console
You may need to reboot the pc.
I recommend a program named Autorun from SYSTERNAL to control what runs on a PC.
Dec 12, 2008 | Microsoft Office 2003 Basic Edition...
Adobe updater window flashing, allowing no access to open programs.
go to www.Adobe.com and download the lastes version and this will remove any old ones from your pc
May 08, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Microsoft WORD pdf menus and pdf conversion facility
try this Deran 1. Open the Microsoft Office program (Word, Excel, Publisher, or Excel). 2. Go to Help > About [program name]. 3. Click Disabled Items. 4. Select Adobe PDF from the list and click Enable. 5. Quit the Microsoft Office program and then restart it. Note:Microsoft Office Applications disable add-ins as a failsafe if the application is prematurely closed (for example, system wasn't shut off properly or the application crashed).
Sep 25, 2007 | Computers & Internet
Open Questions:
See all IBM Lenovo ThinkPad T61 Notebook Questions
IBM Lenovo ThinkPad T61 Notebook Logo
114 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
