Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Water is steadily running/drippin into the drip pan...overflowing
Overflowing onto the floor. Any first thoughts as to what could be happening?
Any first thoughts as to what we can do to stop the leaking from the refrigerator?
    Sergeant:
    Champion:
  • 260 Answers
The frirgerator has a defrost when it defrost it has to go somewhere check the drip pan and make sure it is not full.
If this continues then try checking the water line coming into the back and up the back of frig. try that first
Posted on Apr 10, 2009
DRAIN PAN FULL OF WATER AND OVERFLOWING ONTO FLOOR
What kind of unit do you have? Its possible depending on the manufacture that a water line is the cause as it drips water into the pan causes the overflowing of the drain pan. Look for cracks in all the water line under the unit and you may have to remove the back and the water valve to see it. Good luck
Mar 07, 2015 | Refrigerators
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
Water is dripping into pan under fridge and overflowing onto floor. looks like water is dripping from filter at bottom. what can i do?
Check to see looks like the container is already full. You have to remove the tray full of water and then insert it again. It will happen again and again ( overflowing water) so you need to periodically check the container pan if water is full.
Also by checking periodically that pan, you will minimize rust build up. You will need to wipe around it with soft cloth or rags so the body of your refrigerator will not decaying due to rust built up. This will destroy the metal parts of the fridge.
Good luck.
Jun 25, 2011 | Kenmore Side by Side Refrigerator
Water is dripping into the drip pan under the bottom part of the refrigerator/freezer and overflowing onto the floor.
if it is not evaporating then you need to clean the condensor coils and the fan in the bottom. let me know if this helps.
Apr 26, 2011 | Roper Refrigerators
Drip tray is overflowing water onto floor.
Hi Mickey, You have a bad water valve. Turn the water off to your unit and turn off the ice maker. Replace your inlet valve.
May 22, 2010 | Whirlpool ED2FHEXN Side by Side...
Drip pan is full and overflowing onto floor
If the temperture behind the compressor is not so hot the water will not evaperate. the heat from the compressor dry out the water.
Jan 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is leaking on the ground
Assuming you are talking about water leaking, if it has a drip pan to catch condensation, it may be full and overflowing or missing a drip pan allowing water to fall to floor. If it has an icemaker and/or cold water dispensor, it could be a connection leak.
Oct 08, 2009 | Kenmore Refrigerators
Drain pan of refrigerator is filling up and overflowing onto the floor. This never happened before.
Maybe it is because of increased humidity inside the fridge. This could be caused by the door not being properly closed or leaking.
May 31, 2009 | Maytag MSD2656G Side by Side Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
638 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
