Makes an extremely loud popping noise. the car has been off for a while and while i'm driving it when i press on the accelerator it starts making even more noise.
SOURCE: ticking noise in engine and blue smoke in exhaust
the tapping are the lifts tapping because there is no oil getting to the top of the motor. the blue smoke is the oil burning.could be the head gasket is going bad or the piston rings are done in.
SOURCE: white smoke out the exhaust
hi white smoke is from coolant in the cylnders bed head gasket.blueish white smoke is oil in the cylnders either bad valve seals or bad piston rings.must rebuild engine or heads.
SOURCE: Loud Ticking sound 2004 F150
Check the Alternator / Powersteering belts .
One of them will be damaged and loose.
Hope this helps.
SOURCE: loud banging noise frome rear of car
Were the rear muffler tailpipe hangers checked for being broken or missing? even Engine mounts will cause this and because it does making a left turn you would want to check out the right rear one especially and of course if needed replace all of them...also meaning the hangers for the exhaust system..
SOURCE: 2005 transit loud turbo,no power especially on
The black smoke is blow-by you need a ring job. Oil is getting by the top ring of your pistons in one or more cylinders. Loss of power under a load is also indicative of this.
