We have a Hoover AL130 washing machine. This week it started having a noisy spin, which I tracked down to a loose bolt through the bottom piece of concrete. I fixed that, gave it a quick spin to test, and then pushed the machine back under the worktop.
At first it would do nothing when back in place, so I pulled it out again, checked it had power to the switch, and fiddled with a few connectors. That managed to get the program knob to click around until I switched it off.
Now it is back to nothing working, and there is no fault display mechanism on this model. Is anyone familiar with it?
-   hi
I have hoover AL130 washing machine, it has stopped working. when i press the on/off button lights come on and it takes water but drum inside does not rotate or spin. door is shut properly.
please help me to sort out this problem and thank you in advance
Sorry I was not clear, it is now completely dead even when not under worktop, but out to be tested.
Yes, still dead.
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2007
Charlie - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
If you're saying that it is completely dead when you're pushing back under the worktop, then it sounds like some sort of loose connection to the wall socket or plug or a cut / break in the cable at the machine end of the flex.
Can you plug it in to a different socket or heavy extension lead and then push it back under the worktop to see what it does.
Was this helpful?
Yes
No
Solution #3
Odud - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Yes, there are volts into the back of the machine, and from first component inside, to which the mains lead attaches.
Was this helpful?
Yes
No
Solution #4
LiZzIe - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Useful though the word widget is, it doesn't really help in this case, have you (or are you able to) traced the voltage going into the back of the machine?
-- Ian Tilley Ex-Kirklees Domestic Engineers # it's free
Was this helpful?
Yes
No
Solution #5
paulrmc - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Completely dead, no sounds, no lights.
The mains cable looks ok, and there is still power out of the widget on the back. There is a widget near the programme dial which has an empty spade as well as four wires and a tube, but no detached wire nearby.
Was this helpful?
Yes
No
Solution #6
Rank: Apprentice
Rating: 0%, 0 votes
When you say it is not working, is it completely dead? any noises? sounds like when you pushed it back, you may have kinked a pipe or pulled stressed the mains cable perhaps.
Was this helpful?
Yes
No
Popular Solutions for Hoover AL130 Front Load Washer
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The...
(More)
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The front reset button clicks when pressed after trying the dryer.
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out...
(More)
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out the front of the machine near the end of a wash cycle. Trap is clear, have ha dteh back off and all pipes seems well sealed and connected, it seems to leak from the solid plastic internal casing on the right hand side (as you look in from the back) and runs down the natural curve of the plastic dripping and forming a puddle that then leaks out the front underneath of the machine. Is there a way of fixing this problem , how do i get to it etc
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no...
(More)
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no progress also the express wash light and the select spin light are flashing and the time on the screen is also flashing
