Question about PC Chips P23G Motherboard
2G Memory Upgrade
PCChips P23G(v1.0) MB wont recognize 2G RAM DDR2 1Gx2 kit in BIOS or XP but yet CPUID does
Latest MB BIOS loaded - other BIOS settings to check?
2x512MB sticks are fine = 1G
2x1GB sticks = 1G in BIOS and Windows XP SP3
Both cases, ValueSelect 533MHZ DDR2 using DDR2 MEM slots
  • 2 more comments
  • marklarson Feb 26, 2009
    MB accepts up to 2GB, 1GB per slot max per manual
    MB has DDR and DDR2 pairs of slots, but using DDR2 slots
    DDR up to 400, DDR2 up to 533
    Memory boots in POST at 533MHz, but only 1024MB
  • davidh23 Apr 12, 2009
    i have same problem, im using ram reccomended by crucial.com.
    bios set up does not report memory type(i.e. ddr2, ddr) only speed.
    tried everything i can think off.
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    It sounds like the board/bios is reading it as DDR instead of DDR2. This would mean it's only reading half of each stick. Check your bios setttings to make sure DDR2 is enabled.
  • Roy Lonsinger
    Is the 2 GN kit compatible with your motherboard?
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Posted on Mar 21, 2009
  • PC Chips Master
  • 3,606 Answers
I have the same problem with this mb i just bought kingston 2gb pk single bank and its showing it as 512mb each stick do you think that updating the bios will resolve this?
Posted on Sep 09, 2009
    Scholar:
  • 116 Answers
Sounds like the 2x1gb is double sided. I've had alot of trouble with pc chips and using more than 1 stick of double sided ram.
Use single sided ram, and you'll be problem free with PC Chips, some of the cheap MSI boards are the same way.
Posted on Feb 26, 2009
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Problematic recognition of memory
You may try another OS if you think, this is a software problem. please let me know the update with another os like xp ?
May 24, 2009 | Computers & Internet
Pc Chips P23G wont reconize my new p4 core 2 duo
The PC Chips P23G versions 1.0A & 3.0 will not support any current generation Core2Duo, Core2Quad or Pentium Dual-Core processors. Only some of the first generation (Conroe Core) Core2Duo processors which run @ 1066mhz bus and some Pentium D (presler core) processors which run @ 800mhz bus.are supported. Not even most current BIOS will add support for any current processors. Check the pcchips website for CPU compatibility for the P23G..
Mar 22, 2009 | PC Chips P23G Motherboard
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
P23g PC Chip Mother Board and DDR2 Ram
probably your motherboard does not recognise the faster ram go to BIOS setup and check ram is set for auto
Jul 17, 2008 | PC Chips P23G Motherboard
RAM Memory upgrade: 1gb modeles recognized as 512mb
You may have incompatible memory. double check your order and use only recomended name brand memory such as Kingston, you can look up the correct memory on their website, or on newegg.com
Apr 23, 2008 | Dell OptiPlex GX270 PC Desktop
BIOS detects only 128 MB instead of 1024 MB
Does the motherboard support 1 gig ram modules? what kkind of motherboard/video card do you have? sometimes video card onboard ram can ofset motherboard ram, especially with ati video cards.
Mar 17, 2008 | PC Chips M870 Motherboard
PC Chips P23G Motherboard Logo
1,280 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
