Question about Maytag Atlantis MDG7400AW Gas Dryer
Automatic drying doesn't shut off
Timed drying works normal
  • 117 Answers
If your gas dryer advances to off in timed cycle but not in auto cycle the causes could be that the cycling thermostat has shorted in the closed position, not opening to open to turn the heating circuit off. The timer advances when the heating circuit cuts off and if it's stuck on it will not shut off the dryer. You also could have a timer that is faulty.
http://tclaundryrepair.com/
Posted on Feb 26, 2009
    Scholar:
  • 85 Answers
Its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
  • 958 Answers
SOURCE: machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
the automatic feature could be the problem. the damp sensor could be faulty. the timer would run even though the clothes are still damped. it is supposed to stop while the clothes are still wet.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
  • 20 Answers
SOURCE: Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Posted on Jan 19, 2009
  • 864 Answers
SOURCE: Whirlpool gas dryer has a timer for timed dry and
Auto sensor is not working. Replace it.
Posted on Aug 12, 2009
rogrrabbit
  • 986 Answers
SOURCE: my dryer won't shut off on automatic dry and takes
Runs but dont heat:
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Runs but takes a long time to dry the clothes:
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Oct 16, 2009
richroth
  • 9472 Answers
SOURCE: dryer stopped drying in automatic
The sensor for automatic drying needs to be replaced. If you post your model number, I can direct you to the part.
Posted on Jan 26, 2011
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
DRYER WILL NOT SHUT OFF ON AUTOMATIC SETTING
Most of the time when a dryer won't shut of in automatic, it is because the sensors inside the drum are bad and cannot sense when the clothes are dry. If your dryer works good on a timed dry then is probably the moisture sensors.
Oct 08, 2014 | Kenmore Dryers
Kitchenaid superba electric dryer doesn't dry on timed dry
Sounds like a controller problem. May be unable to start a normal dry cycle
Sep 11, 2012 | KitchenAid Dryers
Dryer working to long to dry clothes
more than likely the belt needs to be replaced and the unit needs to be cleaned out (too much lint built up in the unit)
Apr 13, 2009 | Dryers
Jan 19, 2009 | Dryers
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
205 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
