Question about D-Link DIR-625 (790069292637) Wireless Router
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to comcast cable modem SB5120, ethernet cable from d-link to comcast cable modem. Will not describe the many failed configurations I have attempted. Will someone please describe the setup process I need to complete to make it all work? I am a mentally challenged, pc illiterate individual so please provide detailed instructions. Laptop's device mgr shows PCI Modem, Ethernet Controller, Network Controller, SMBUS Controller, and PCMCIA ethernet card are all yellowed out and I can't find Drivers for any of those components. I can get online with each, independently, but cannot get online with both at the same time - need to setup, separate, main PC with ethernet connection/cable & laptop with usb connection/cable in order to gain, independent, internet accessibility A speedy reply will be greatly apprecviated.
    Scholar:
  • 93 Answers
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Posted on Feb 27, 2009
  • Denis K. Feb 27, 2009
    As for the drivers, use google to find them, if they were originally part of your system, go to your manufacturers website, and go to their support/download section to find your drivers, and install them. If they were added later on to the system, just google it/go to the manufacturers support section as well.
    Especially for the PCMCIA ethernet card, you should go to the manufacturers site to download the drivers there (from support/downloads), since it is a card/addon.
At&t broadband router hooked up to DES-1105 to two computers , 1 has windows 7 the other is windows XP and get an error stating 2 computers with the same IP
you should click on the local area network and find the option configure ip chang the ip from there.you can do same work in internet exproler properties
Jan 29, 2010 | D-Link Desktop Switch DES-1105 5-Port
After install of d-link ''DES-1105'',computer shows ''no connection''
go to control panel, network connections, check for available network, if that does'nt do it search for new harware and run th install wizard.
Nov 20, 2009 | D-Link Desktop Switch DES-1105 5-Port
I am trying to setup up a D-Link DES-1016D, 10/100 Fast Ethernet Switch to allow 5 laptops to connect, 1 cat 5 is connected to another switch that will provide these 5 laptops internet how can i do this? I...
The Simplest Way of doing this is this:
You will need just 1 switch and 5 Straight-Through cables.
(This is Provided that your laptop will connect to the internet through another method. e.g (Though a USB Modem or WIFI) ).
Connect the Main laptop to the internet through either a USB Modem or a WIFI.
Next, Connect a straight-through cable to the LAN Port of the laptop, and the other end to one of the ports of the switch.
On the network connections page, right-click on the ethernet adapter, go to TCP/IP, and give the laptop a static IP-Address, e.g 192.168.0.1 and Subnet 255.255.255.0
For the other laptops, connect each one of them to the switch using the straight-through cables, and on their ethernet adapter TCP/IP Properties, give them different IP Adresses, but in the same subnet. e.g
192.168.0.2 and 255.255.255.0 for the 1st one
192.168.0.3 and 255.255.255.0 for the 2nd one
192.168.0.4 and 255.255.255.0 for the 3rd one, ....and so on.
Next, in the default gateway for these other laptops, put the IP-Address of the First laptop that is connected to the internet. i.e 192.168.0.1.
Also repeat the same IP Address of the 1st laptop in the Preferred DNS Server for these other ones.
Next, setup home or office network on all of them,
follow on-screen instructions and when you get to the place where you have to select the type of network setup, Just select :
"This computer connects directly to the internet........" for the 1st laptop,
For the others, select : " This Computer Connect through a residential gateway or other computer on my network.".
Then give them all the same workgroup name, and accept file and printer sharing for all of them.
In case you are using Windows Vista.
The only different things include:
When you get to the TCP/IP Place, select TCP/IPv4 and Not TCP/IPv6.
Also, When you are changing the workgroup, all you need to do is to right-click on My Computer Icon, then Properties then go to Advanced, then Select Computer Name, and change the workgroup from there and restart the computer.
What I have told you is a typical, very easy network setup, and I do hope it helps you out.
Keep me posted about the problem.
Hope it helps you out.
Good luck
Nov 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Trying to hook up rotoer
no its usb. install the modem drivers on your pc and plug the modem in via usb.
May 20, 2009 | D-Link Desktop Switch DES-1105 5-Port
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
D-Link DES 1005D
set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure  enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
Oct 18, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
D-Link DIR-625 (790069292637) Wireless Router Logo
389 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
