Question about Avanti W789SA Top Load Washer
Avanty w789SA Water from machine doesn't go out each time What to do? Valie
  • 85 Answers
Its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Feb 26, 2009
Where is The Lid Swith Located In Avanty Washer
Yes,it is located at the top rear portion of the machine and two white wires are connected to it.To gain access,remove two screws holding the cover(from the rear).
Apr 14, 2013 | Avanti W789SA Top Load Washer
My machine wont spin or turn i took the back off the machine and in the tank there is water in it and wont come out
firstly,the machine will not spin if water is in it.the spin cycle starts when the tub is drained of all seems to have one or a combination of these problems; drainage/blockage/pump motor/no signal/no voltage.does the machine complete the wash cycle?
Nov 20, 2012 | Avanti W789SA Top Load Washer
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
Water running from machine every time when i start to wash
Possible leak in the ddrain hose, the drain pump/valve.
It will be ideal to have a first observation with a good light below the unit to confirm.
Oct 31, 2010 | Avanti W789SA Top Load Washer
Replacement hose needed
Assuming you mean the supply hose, you can get them at most hardware store, plumbing store or any where washing machines are sold.
Jun 10, 2010 | Avanti W789SA Top Load Washer
Nov 13, 2009 | Avanti W789SA Top Load Washer
Drain hose cracked and leaks water
You just have to replace it. Try these sites for spares with your model number, etc:
Apr 12, 2009 | Avanti W789SA Top Load Washer
Avanti W789SA Water valve problem
Where do you live.I know some chenese guys who sell the spare parts.
Dec 14, 2008 | Avanti W789SA Top Load Washer
Re: machine can't drain the water.
Need a more info but lets see if the machine wash ok but dont go to the nex cicle you got a timer problem, the contacts of the timer could be dirt or worn out some times "ants" blocks the contact and just spray them with a contact clenear spray is the solution but be carefull disconect the machine from the ac outlet before work in that area if not then change the timer....good luck and rate me
Feb 17, 2008 | Avanti W789SA Top Load Washer
Avanti W789SA Top Load Washer Logo
168 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
