Question about Panasonic Office Equipment & Supplies
Code e 140 on a fp 7113 copier
Code come on after one copy then will reset after left door is open/closed. How do i resolve this and what is the code for?
  • 163 Answers
SOURCE: fp-7713
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
Posted on Sep 14, 2007
MitchSchaft
  • 25 Answers
SOURCE: Panasonic FP-7735 Error Code E3 40 Help!!!!
E3-40 is a toner density sensor error. It's probably toner getting built up on the sensor. It's located under the drum. It will look like 2 little LED looking things on a little circuit board about 3-4 inches long and half an inch wide. You can blow it out with canned air.
If that doesn't work, then the sensor needs to be replaced.
Posted on Jan 24, 2008
  • 58 Answers
SOURCE: Panasonic FP-7113 Plain Paper Copier
Service Time imageunit can be removed with two screwsand remove tank before lifting out. You can remove drum and cleaning blade section yourself 4 screws. Two on the cleaning and two on the removablr pins on the side.Then remove blade with two screws and fit cleaning blade and drum and reinstall.
Service manual for service mode to remove spanner display F9 ??
Cheers Justin
Posted on May 01, 2008
checkitright
  • 1362 Answers
SOURCE: Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Posted on Aug 12, 2008
  • 92 Answers
SOURCE: How do I fix E3-10 on a Pansonic copier- Model FP-7713?
its a charge assemby problem it has to b cleaned not a big thing 7734748865
Posted on Jun 29, 2009
Code c06F1
Scanner Motor is bad or sensor in the scanner is bad the section under the big glass is consider that scanner. Does the bright lite come on if you keep the document feeder up and make a copy? Does it move to scan the document? cable broken one each side of the scanner as it moves. Open close the front door. to reset or try open front door to the upper left small access plate one screw remove push small button.
Feb 22, 2014 | Minolta EP4000/5000 CS/PRO Copier
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
Error Code U 6
Error code U-6 means the door on the RHS of the machine is not closed properly.
Jun 24, 2010 | Panasonic FP-7735 Black and White Copier
We are getting a code H5-01 what does this
H5-01 means there were five consecutive jams at the fuser section. Open the left jam door and look up in the fuser (heat) section and at the top of it You should find sheets crunched into an accordian After clearing all the paper from this area close up the copier Turn it on and press the copy mode key Then the following keys in order one after the other Program..*..C..* The display will change to service mode input 14 then the copy start key enter 1 for yes then the copy start key if the copier does not restart itself then hit the CA key the copier sholr reset and start with out the code
Feb 17, 2010 | Sharp AR-M355U Copier
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
ERROR CODE CO5OO FOR MINOLTA CS/PRO 2080 ????
This is a lamp error, check that is not burned, or the thermal fuse.
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
Warning: Be advised that with fuser codes, some RISKS are involved, PLEASE SEEK PROFESSIONAL HELP to reduce these risks.
Thank you and good luck!
Jun 18, 2008 | Minolta EP4000/5000 CS/PRO Copier
Panasonic 7735
Hi Yes can help but need to know the code. If you open and close front cover machine should reset.If not need the code
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
1,065 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
