Question about Dell Dimension 3100 PC Desktop
Computer not coming on
Hey all have a problem with my dell dimension 3100 desktop pc put on the power but it's not coming on and the power button stuck on flashing ambr light can anyone help me
  • 2 more comments
  • scorpionbluf Feb 26, 2009
    no beeps no sound no nothing
  • AntsMc Mar 26, 2009
    I have a Dell Dimension 3100 desktop with XP, the PC won't boot.
    The numbers 3 and 4 are lit on the front and the power light is on.
  • Anonymous Mar 28, 2009
    I got the sam, PC starts to boot, beeps, and the numbers 3 and 4 light up but nothing hapens.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Can you tell me if the computer is beeping?
  • Dell Master
  • 4,806 Answers
Jsparo could be right, however, there could a number of causes for this, start by opening the side panel, take out the system memory, clean the memory contacts and slots of dust with a dry, clean, soft paintbrush, re-seat the memory firmly and try to boot the PC again.
Make sure you pull the power cord from the rear of the desktop before opening the side panel.
Good luck and thanks for using Fixya!!
Posted on Feb 26, 2009
    Sergeant:
    Champion:
  • 357 Answers
Flashing Amber Light on a Dell Desktop is a defective power supply.
You can get a replacement from various vendors, or Dell.
Good Luck.
My dell dimension 3100 won't power up,it's in the standby mode.what can i do?use hiren's boot disk?
Hi, to release computer from standby mode, you could remove battery, put it again an turn on computer, Windows will show computer was not turned off correctly but now you can continue using it.
Nov 08, 2015 | Dell Dimension 3100 PC Desktop
When i start up my dimension 3100 dell desktop instead of a green light i get a flashing amber light. people say it is the power supply but the light wouldnt even come on if it was. can you please help me?
No, the light WOULD come on if it was a Power Supply problem.
1) If ALL of the LED lights on your computer were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses from 51 to 125 Watts. Depends on what Processor it is.
Dell Dimension 3100 desktop computer?
An Intel Pentium 4.
Intel Pentium 4 model 640.
Can operate up to a frequency rate of 3.2GigaHertz. (3.2GHz)
Fits in a Socket 775 processor socket. (Also know as Socket T)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890.C2.A0nm.29
Can use up to 84 Watts.
You have enough power to light that LED light, but not enough power to turn the Processor on.
Dell Support > Dell Dimension 3100 > Service Manual > Advanced Troubleshooting > System Lights,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124612
"Power Light - Blinking yellow - A power supply or system board {Motherboard} failure has occurred"
Dell Dimension 3100 desktop computer Service Manual, (Free from Dell Support),
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
Click on Removing and Installing Parts > Power Supply
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 20, 2011 | Dell Dimension 3100 PC Desktop
Working on dell dimension 3100/e310 desktop pc. when u press the power button u get a soid green light with beeps and the diagnostic light are green on lights numbered 3 and 4. need help badly
Constant beeping on power up can be a memory issue.
Locate the memory module and reseat it by taking it out and putting it back. Do this with the battery and power adaptor out. The module is normally located under a cover on the base of the computer.
Feb 19, 2011 | Dell Dimension PC Desktop
Can't get Dell Desktop to recognize cd/dvd on D: drive
With any computer this is a question that must be answered by those that provide the driver software. Like the number above (Dimension 3100) you should begin your search here=> Dimension 3100 Drivers that is if you have not altered the driver by putting a different player in the slot. What you need to do is test the drive using the Dell diagnostics. The procedure can be found in the CD/DVD FAQ. Run the "read test". You'll need to insert various disc types during the test. This came from Dell Forums. Click Here=> Dell Forums/Osprey and Here=> Search Results for "Dimension 3100 DVD Driver"
Hope this helps, Thanks, Sea Breeze
Jul 14, 2010 | Dell Dimension 3100 PC Desktop
I have a Dimension 3100 everytime I turn on tower an orange light comes on Please help???????
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 won't start.
Check to see if the monitor cable is connected properly.
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
No power up no post no nothing on dimension 3100
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. It sounds like you have isolated the problem to the motherboard since you removed everything but the board and power supply. You may be able to locate one by browsing the internet. Just type in “DELL Dimension 3100 motherboard” and see if you can locate one at a reasonable price.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You
Sep 27, 2008 | Dell Dimension 3100 PC Desktop
Dell 3100 no coming on
Did you checked whether the CPU / tower is turned on.. press some keys on your keyboard to make it active.
This might looks funny but it works all the time :)
Jun 25, 2008 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
383 people viewed this question
Alun Cox
