Lg minisplit heat pump will not heat
I purchased an lg minisplit heat pump system over the summer and installed it in August and it cooled great. When it was put into the heat mode, it was blowing cold air. I found the reversing valve not energizing. I replaced the board on the outdoor unit. Now when the system is put into the heat mode, you can hear the reversing valve energize but nothing else happens except the indoor blower comes on and runs for about 10 seconds. I cannot find any technical manuals or any place to get help.
  • Anonymous Mar 25, 2009
    HI ours have the same problem...its exactly does the same thing having the guys to see it as its under warrenty at the moment..works fine in cool mode
  • 400 Answers
You may want to check that the pressure switch is not functioning? Secondly there is also a thermo sensor on the condenser coil which could be faulty.
Posted on Mar 04, 2009
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Hi there I have a LG esnw126 inverter,when I set it on cooling it doesn't run at all.the cooling indicate light is flashing 6times and flashing 2 times on the heating indicating light...help please
Our AC has had a lot of trouble over this summer and we recently had an issue just like yours. We ended up calling an air conditioning repair technician and had it resolved. It was the best thing that we did this summer because it is really hot right now but inside it is great! Ontario CA Air Conditioning repair Penny Plumbing
Aug 24, 2015 | LG Heating & Cooling
I have a LG minisplit (indoor unit LSN122HE /outdoor unit is LSU122HE) it cools great dehumidifies also and has for 3 months of summer. However its cold now and it will not heat. It runs for a min out
That's an inverter series motors... the outdoor fan motor is on an ambient controller to maintain pressures when cold outside in air conditioning mode, but not in heat...only defrost when needed. Check the settings on the outdoor board for defrost timing
Dec 02, 2013 | LG LSN122HE / LSU122HE - 11,500 BTU 13...
Whirlpool mini split
Peek inside the opening on the front of the inside unit. You should be able to see the blower assembly/fan blades. See if any of them blades are cracked, warped, or debris on them. If seen these minisplits mildew on those blades also, which will cause it to be off balance. If you move the fan to different speeds does the sound change? If its down that since day 1, its probably a defect. Hope this helps!
Mar 13, 2017 | Heating & Cooling
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
Hello, I purchase an LG dual split minisplit air conditioner. It worked all summer long but now both wall units display a "CH 46" error and do not turn on. Any idea what the problem is and how...
A CH46 error indicates the low side sensor or suction line sensor is defective and not within acceptable parameters. It may be loose or off or simply bad.
Sep 12, 2011 | LG LS-L1210CL Mini Split Air Conditioner
We gave a Goodmn Hertz 60 Phase I heat pump - installed this summer....worked great for cooling..now that temps are dropping we are needing heat. When we turn it on it comes on but never heats. Think it...
If you changed the unit but didn't change the thermostat it is possible that the thermostat that you have will not work with that unit. I see that the unit you installed is a heat pump, you may have a straight cool T-Stat. If you put the T-Stat in the "Auto" "Heat" mode the outdoor fan and the compressor should be workng as well as the blower fan. If it turns out that the outdoor fan and compressor are not running you will want to buy a Thernostat that is compatable with heatpumps should be 2 heat/ 1 cool
Nov 05, 2010 | Goodman PHKJ048-1 Air Conditioner
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Looking 4 a minisplit - heating & cooling - 12,000 btu 16-20 SEER
I have been doing this for 45 years and for the price the Amcor is the best because they send you everything you need to install unit. I just installed one for my neighbor18,000btus He paid 1000 included shipping. The tech support is great. Russ
Jul 25, 2009 | Heating & Cooling
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Heating & Cooling Logo
1,125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
