Question about RCA P52926 52" Rear Projection Television
Rca 52" rear projection tv (P52926) volume control LOCKED!!!
I have been having a problem with my rca 52" rear projection tv where the volume control is locked, i can not rasie nor lower the volume, sometimes i have unplugged the tv to reset but lately that has not worked, when it has worked the display on the screen shows the time, the channel and an item that says UNLOCKED, then i can adjust the volume otherwise i can not adjust the volume. if anyone might have a solution i would greatly appreciate anything at this point. (manuf. 2000)
  • gary garcia Feb 26, 2009
    thank you very much will follow your recommendations
    President:
  • RCA Master
  • 1,779 Answers
This can be a tricky one, I would check the 5 and 3.4 volt lines first with a DVM (analog meter will not due) then with a scope to see what the voltages are and what they look like. A bad cap on the rail for the e-prom can cause this or the eeprom may be bad, this also happens. It might be best to contact a scv. co. as you can a lot more problems in that area if your not familiar with it.
Posted on Feb 26, 2009
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
My 52 inch rca rear projection tv will not power up?
Hi abmerchand,
Do you have a standby light, blinking led light, or totally dead set...
I need to know to assist you further...
Jdvillanueva
Mar 05, 2011 | RCA P52926 52" Rear Projection Television
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume
Unplug the tv for 30 seconds. It is a tempoary fix
Mar 11, 2008 | RCA P52926 52" Rear Projection Television
PCB for a 52" RCA Rear Projection
Solder Bridge on power switch to ground SW13201
Dec 26, 2007 | RCA P52926 52" Rear Projection Television
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
