Question about Maytag Neptune MAH5500B Front Load Washer
Door will not lock so washer will not spin. Water is draining out.
  • 57 Answers
You need a wax motor and control board for the machine that is a common problem with the neptune. if you take the srews out of the head and look at the board yu will see a bad resistor just above a long blue resistor. make sure you upgrade your wax motor when you do the board or it will happen again
Posted on Feb 27, 2009
    Scholar:
  • 85 Answers
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
for more diagramatic and detailed help just click on the above link
http://www.applianceaid.com/neptune7.html
Posted on Feb 26, 2009
My Asko washer model number WL6511XXLPP will not spin it is draining what's the problem
All front load unit must lock the door and drain all the water prior to spinning. If your filter inside the drain pump is clogged this unit will not spin. At the bottom of the washer is a door, open this door and unscrew the plastic cap. *This is the lowest spot on the washer, so this will hold water, be prepared for water* After you clean this out, run a rinse only cycle and re-test unit, if the unit fails to pump out completely, replace the pump. Good Luck
Aug 04, 2014 | Washing Machines
Frigidaire washer does not drain
Remove the drain hose from sink Unplug machine Safety 1st....put hose over bucket should gravity drain next take out the filter if its got one bottom /right hand side of machine clean...if not locate drain pump and remove blockage...kids sock maybe? Door may reset after water has been removed and unplugged .Good luck
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
Door will not close
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Can't get the door open
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Door lock light is on door is not locked and
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Frigidaire affinity door will not lock when door is closed or register door is not closed when open
Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Maytag Neptune MAH5500B Front Load Washer Logo
76 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
