Question about Smith Micro CheckIt Utilities (CKUWINKESMS1153) for PC
I recieved a floppy disk called check it portable edition from a friend and it will not download . Could you tell me why? Crystal
This was a stand-alone diskette that could boot on any standard PC where the BIOS allows booting from a 3.5" floppy. It doesn't 'download' it just runs and gives you a lot of information about the PC and installed hardware. There are also some hardware tests that can be run. If you received a license number, you can run all the tests, otherwise you get a more limited product. The license number is not the Serial Number.
Smith Micro no longer supports the product.
woth1918@hotmail.com
Posted on Sep 07, 2009
NewerTechnology uDriveSmartDisk USB Floppy Drive (model FDUSB-M, Color Kit Edition, formerly VST)
Verbatim continues to offer support on select SmartDisk products:
CrossFire USB & FireWire Desktop Hard DrivesSOHO NAS Desktop Hard DrivesFireLite USB & FireWire Portable Hard DrivesFireLite XPress Portable Hard DrivePhotoBankUSB External Floppy DriveSelect models of CameraMate Card Readers
For online support click here:
http://www.verbatim.com/contact-login.cfm
or call technical support at 646-537-3411, Monday-Friday, 8 a.m. to 9 p.m. Eastern Time.
Verbatim Acquires SmartDisk External Hard
Disk Drive Business
Verbatim Acquires SmartDisk External Hard Disk Drive
TOKYO, (July 5, 2007) - Verbatim® Corporation and its parent company Mitsubishi Kagaku Media (MKM), announced today the purchase of substantially all of the assets of SmartDisk® Corporation\'s external hard drive (HD) and digital imaging business.
The acquisition, which includes physical assets, patents, trademarks, technology, engineering and marketing expertise, was effective on June 30, 2007.
Feb 12, 2013 | SmartDisk USB Floppy Drive Titanium...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8 Home Edition http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=8030 Professional Edition set up disks for floppy http://www.download3000.com/download_17676.html XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
When i try to run a disk it says the disk is not formatted do i want to format it now. the disk has information on it so it has to be formatted .
It is possible that there are errors on the floppy disk or the disk was formated using a format that is incompatible with the current operating system. If the disk is readable on another system, the best solution would be to copy the files onto a portable USB flash drive, then reformat the floppy disk using a filesystem that is readable on the desired computer.
Apr 22, 2011 | SmartDisk USB Floppy Drive Titanium...
I have a USB portable diskette external floppy drive. It is new. It is supposed to work by simply plugging the in teh usb. When I try to use it, it always tells me to format the disk. i of course, do not...
Try different and empty disk, then format it, when you can open it after you format it, then your first disk is damaged.
If still persist, then clean the drive using floppy drive cleaner, it should work.
Oct 17, 2009 | IBM USB Portable Diskette Drive (05K9276)...
My floppy discs will not format message I recieve , This disc cannot format
Maybe the is no longer usable.. or the disk is corrupted, try another disk..
thanks
Sep 23, 2009 | Microsoft Windows Xp Home Edition Sp2...
Micron Transport Trek 2 mod#NBKU370, ser# 1392070-00311
I think it means that either the hard drive has failed, or that it is not detecting it. try downloading a program called Bart PE Run this disk in the CD Drive on startup. then find the option called command prompt. then type in the following as follows:
chkdsk C:/r
after this finishes, shutdown, remove the disc, and see if the laptop will boot now.
Feb 05, 2008 | Computers & Internet
Smith Micro CheckIt Utilities (CKUWINKESMS1153) for PC Logo
143 people viewed this question
Top Smith Micro Computers & Internet Experts
Les Morrison
Les Morrison
RSole
Are you a Smith Micro Computer and Internet Expert? Answer questions, earn points and help others
