Question about KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water
Kitchenaid ref's icemaker water line shutoff
After taking the ice bin for clean, the waterline is shut off but the water dispenser is still working
    Scholar:
  • 85 Answers
Have a new frigidaire how long does it take for ice bin to fill after waterline install
Ice maker will call for water 12-14 hours after plug in. If the ref was running and then Waterline was connected it should call for water in 4 hours or less. Easy rule, after 24 hours, ice bin should be full.
Dec 05, 2012 | Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
No water in icemaker
Please click on the blue links which are underlined to get more info.
Here are the check's which you can do:
Goodluck..
Feb 19, 2008 | Frigidaire FRS26F4C Side by Side...
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
Galaxy ice maker dispenser runs but does not dispense ice. So far as can tell it is not clogged
Check your manual, there is a wire or device to shut off icemaker when the ice bin is full it is pushed up to stop the ice making process. Make sure it is not stuck in the up position (off) and is pushed down so it can freely move up and down. If that is not the problem it could be a bad micro switch for the shutoff device or a bad water valve.
Jan 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
ICEMAKER NOT MAKING ICE
Dear Customer
Please perform the following checks
Please rate this ,Thank u
Dec 17, 2008 | Refrigerators
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid 22.0 cu. ft. Side-By-Side Refrigerator with AquaSense In-Door-Ice and Water Logo
553 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
