Question about Yahoo YHT-630 System
I need a CURRENT circumventor!! - Yahoo YHT-630 System
  • 20 Answers
Whats that?
Posted on Mar 01, 2009
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
What is my current rate
Which current are you referring to ??......
If you think of an electrical device as a piece of plumbing, voltage is the amount of water that you send down into the pipe, resistance is the pipe's relative width or narrowness, and current is the speed with which the water flows.
Power measures the water's relative difficulty or ease making its way through the pipe.
You relate all these values to one another using a common set of physics equations known as Ohm's law.
If you need to calculate electricity's current flow, you'll need to have at least two of the three values -- voltage, resistance or power -- listed above.
Calculate current flow using voltage and resistance.
According to Ohm's law, you can express electricity's current in amps as a ratio of its voltage in volts to the resistance of the device it's flowing through in ohms -- I = E/R, respectively.
For example, if you want to know the current flow of 220 V of electricity as it flows through a laptop computer with 80 ohms of resistance, you would simply plug these values into the equation as follows: I = 220/80 = 2.75 amps.
Calculate current flow using power and resistance.
Ohm's law also states that electrical current, "I," is equal to the square root of the power dissipated as it travels through the device divided by that device's resistance.
If a light bulb dissipates 80 watts of power and has a resistance of 55 ohms, you can calculate the electricity's current as follows: I = sqrt(80/55) = sqrt(1.4545) = 1.20 amps.
Calculate current flow using power and voltage.
If you have a space heater which dissipates 420 watts of power when it takes in 120 V of electricity, Ohm's law states you can calculate this electricity's current using the equation "I = P/E." For this example, compute current like so: I =420/120 = 3.5 amps.
http://www.the12volt.com/ohm/ohmslaw.asp
Aug 13, 2013 | Computers & Internet
Cannot connect with webex
"Over current" means you are drawing too much current from that port. If you have several USB devices attached at the same time it may be that you have too many and the system cannot supply the current needed. OR your machine isn't putting out enough current. Try unplugging everything but what you absolutely need.
Jun 23, 2013 | Microsoft Windows XP Home Edition
Can I get your hotspot so I can get on facebook at school
Most schools enable a firewall to restrict you from visiting inappropriate websites, images or other material. Unfortunately sometimes they block perfectly legitimate stuff, which sometimes you need to access for a school assignment. In these cases, here are a couple tips for bypassing your schools internet security.
Try putting "https://" before the web address, instead of just http://, this works a lot of the time if the website supports it. If your school has not already blocked it, you can go to www.sefreak.com and sign in to the portal using the username student and the password random1 to gain access to a really quick proxy. If your school frequently updates the block-list, and you want to always stay informed about the latest proxy websites, you can sign up for a mailing list here: http://www.peacefire.org/circumventor/ If you have access to your own computer, consider computer programs such as UltraSurf or HotSpot Shield which help get around internet censorship. For the more technologically-inclined, you can set up your own proxy server using a running computer connected to the internet at home, or using Google Apps: http://lifehacker.com/5484934/run-your-own-free-proxy-through-the-google-app-engine
Feb 21, 2013 | Dell Latitude E5500 Laptop
How to open blocked facebook
http://peacefire.org/circumventor/
this site will give you a link to a proxy server that masks the request for facebook as somthin gallowing you to access most banned sites in most areas works against sonicwall the best i have ever seen(the industry leader)
Mar 06, 2011 | Computers & Internet
Cant get in to myspace at school
You could try using a circumventor (proxy) a great resource is http://www.peacefire.org/. try signing up for there mailing list, they send out an email with a circumventor every week.
Oct 30, 2009 | MySpace Computers & Internet
How to get on myspace with it is blocked
Ha, champion.
Use a redirector like www.sourclock.com. Use a PRIVATE email address to subscribe to their mailing list, and be sure to use "Private Browsing" in Internet Explorer or Firefox.
That circumventor probably won't be around forever, and won't work if you're at a decent employer, or school that uses a whitelist.
Just don't get fired.
Oct 12, 2009 | MySpace Social Network
Washing machine pulls ca then c1 code. seems to be the calypso action problem. does it need a new motor
The C1 code signifies "Average current limit Or Instantaneous current limit."
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or C1 for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem. "
Please check down the drive motor to resolve the issue.
Have a blessed day!
Thanks!
mannu_rakesh
Sep 01, 2009 | Washing Machines
Internet
Use a proxy service to enter the sites. Use one of the following links & enter your destination URL.
2. Use Google to load the cached (usually filter free) version of a website or proxy.
example: - goto google.com, and type in demonproxy or demonproxy.com - goto the first link by clicking on cached (not the real URL link). - type in the website you’re trying to goto in the URL bar and enjoy.
example - use http://home.myspace.com (instead of http://www.myspace.com). Other prefixes to try for myspace.com: browseusers. search. invite. mail. blog. invite. favorites. forum. groups. events. viewmorepics. music. classifieds. signup. chat. vids.
4. Install Circumventor - please read instructions carefully. 5. Block-Unblock your home network.
May 15, 2008 | Computers & Internet
Yahoo YHT-630 System Logo
137 people viewed this question
Top Yahoo Audio Players & Recorders Experts
Greg Ulan
micky dee
Kolbrun...
Are you a Yahoo Audio Player and Recorder Expert? Answer questions, earn points and help others
