Question about AT&T 1722 Digital Answering Machine
Show me where the cords go
How do i plug it into my phone
    Scholar:
  • 85 Answers
Http://telephones.att.com/docMgt/public/art/20295/1722_manual.pdf
click the link and checkj out the proper connections.
Posted on Feb 26, 2009
I've just bought the above phone and connected tomains to charge batteries and handsets show "line chord error" is this because the phone line has yet to be plugged in?
yes, it will either show line cord error, or no line. After phone is charged plug line cord in and it should go away if not check line cord or try another known good cord.
Aug 11, 2015 | Lands Phones
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
What is wrong with my iPhone?
Are you using the cord that came with your phone? Make sure you have an Apple certified cord and adapter. Hopefully that helps.
The next issue to look at if this does not solve it could be the connection between cord and phone.
Jul 17, 2014 | Apple iPhone 4S
My phone will not take a charge or power up
Confirm that the charging port is working (it may have cable connection issue, and have to be place in a certain position to charge), If the port is fine, then figure if battery is bad.. If charging port is bad, its a relatively easy and cheap fix.
May 29, 2014 | HTC Vivid
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
1/15/09
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
MY PHONE IS DEAD, WONT TAKE A CHARGE WHAT WRONG!
Does it show life of being charged when you plug it in? If so, then it sounds like its time for a new battery. If the phone does not show charging occurring when plugged in, then I would look into seeing if the cord is damaged. Plus the phones charging port could be damaged and not allowing the power to pass through it. Hope this helps!!
Dec 19, 2009 | Motorola Mobility TracFone® V170 Cellular...
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Lands Phones
My phone has a answering machine with it but i now have call answer with cable how do i set up the phone to show that i have messages
If you want to use a different answer machine just run the phone line from the wall to the machine you want to use. Be sure you plug in the cord that say's "Line". Then use another cord that will plug into the answer machine that say's "phone". Plug that other end into your phone and be sure to turn the answer machine off on the phone. Good luck.
Apr 15, 2009 | Uniden Cordless Phone
Fax machine shows message "external phone". Machine is a Philips Magic 3 primo
The message means that a telephone connected to the machine is off hook. Either that or the internal relay that seizes the line after a phone is used has hung up. In that case, try removing the power to the machine and unplugging the line and any other phone cords connected to the machine. Then 1st plugging in the power cord and wait until the machine powers up. If the error code doesn't appear, then plug in the line cord.
Aug 19, 2008 | Office Equipment & Supplies
AT&T 1722 Digital Answering Machine Logo
60 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
