Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Vacuum cleaner will not pick up
I have a kenmore vvacuum cleaner model #216.37010 it will not pick up dirt from carpet. I have took all of the hoses and clean them but the dirt still get clogged in the hose running from base of vacuum.
  • Anonymous Mar 17, 2014
    I took vacuum apart to clean filters & the bottom of the dirt cup came apart & now it will not stay closed A plastic part came out of it; need diagram on how to put it back together
    Scholar:
  • 85 Answers
My dirty devil vacuum cleaner is not picking even the tinniest dirt off the carpet
Has the hose at the clearer head gotten clogged with carpet fibers, that is the common reason for this.
Sep 21, 2016 | Dirt Devil Vacuums
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
The Dirt Devil Featherlite vacuum cleaner throws up the dirt back out. Sometimes the vacuum cleaner doesn't pick up any dirt
You have a blocked vacuum hose take hose off and out side. Push the garden hose from one end to the other, this will push out the blockage
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Model #169171 not sucking up dirt
I have the same problem. When I pull the hose out it seems to have plenty of sucking power though. I dont know what the problem is and why it wont pick up much from the carpet. The stuff it does pick up never seems to make it into the canister either.
Jan 23, 2010 | Kenmore 85930 PowerSpin Deluxe Upright...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
The vacuum cleaner does not pick up anything from carpet. It does not even pick up pieces of thread laying on carpet. On tile floors it blows dirt away instead of picking it up. I've tried all the settings...
Sounds like there is a clog..
Usually its in the hose - look closely.. Stretch the hose out straight and look in there good..
Or a clog could be in the vac close to where the hose conects to the vac on either end..
This is most case scenario with these types of vacs..
I hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Hoover U5269910 Bagless Upright Vacuum
Vaccum cleaner not picking up (116.36933/Aspiradora)
Joan,
I had a similar problem with my upright and just resolved it today. Mine was also picking up with the beater bar, but not as good as it should and it had very little suction at the hose.
I did everything it said to do in my owners manual...
I looked into every entry to the dirt cup.
I checked for blockages into the bottom of the vacuum.
I cleaned the HEPA and regular filters and dirt cup - still no success.
I made sure the belt was working properly.
I finally sat and looked at how things should get into the clear dirt cup (bagless model).
I finally realized it had to be a blockage in the hose.
I completely detached the hose from the vacuum - this took some muscle.
Took the hose outside and used my high pressure nozzle on my garden hose to spray out the hose. It took a few seconds before a pretty large & stiff piece of paper (2"x2") and much more very dirty stuff finally blew out...
No wonder the vacuum had no suction!!!
The paper that was blocking the hose reminds me of a piece found under a Reese's Peanut Butter Cup! YIKES, it was probably candy causing yet more problems besides the extra pounds!!!
Hope this helps - I'm not an expert, just a frustrated cleaning fanatic who hates it when mechanical things don't work right!
Good LUCK!
rtwospeed in Henderson, NV
May 27, 2009 | Kenmore Vacuums
My vacuum will not pick up even fuzz on the carpet
If the suction is strong through the hose and its still not picking up, then something is definately clogged despite the strong suction and rolle brush. Check all inspection tubes including the main dirt channel behind the roller brush. You may find something that keeps getting in the way when dirt or hair is trying to bypass through.
Jan 23, 2009 | Kenmore 31913 Progressive Direct Drive...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
383 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
