Question about Acer Aspire One Netbook 8.9" Notebook
Ram upgaded 1G to 1.5G
I have just replaced my 512 removable RAM card for a 1G in my Acer Aspire One AOA 150-1283 for a total 1.5G do I have to do anything other than install the card? The memory shows its there and computer runs great! Does it just know its been upgraded? I was told I might have to do something with BIOS?? THANKS
  • 679 Answers
Hit start, control panel, system, device manager, and look under 'General" on the main screen, it should say right there the processor and ram type and size. If its not listed click on the hardware tab, go down to the memory, and click on memory/ram, it will be listed there. If it isn't showing or showing is showing he wrong speed, then go into the bios, by rebooting and selecting the delete key. If it shows under the memory speed, that it is the wrong speed, just click on that entry using the arrows esc, and enter keys to navigate the bios program. Highlight it and hit enter, select the proper speed ,hit f 10, and enter to get out of the bios menu. That should set the proper speed if it wasn't correct, good luck, you already did the hard part.
Posted on Feb 26, 2009
  • 129 Answers
There is nothing else needs to be done. If system is recognising the new ram and is working fine.. its a job well done. Just enjoy the upgraded PC :)
Rate the solution as Fixya !
Tnx,
AD
  • Acer Master
  • 4,806 Answers
Hi there.
The computer will recognize the memory as soon as you have installed it and booted the PC up, while you are in windows, right click on computer, select properties and the installed memory will be shown in that window
Good luck and thanks for using Fixya!!!
  • 4,472 Answers
That is all you have to do if it recognizes the ram you are done. Enjoy! Please take a moment to accept and rate my solution.
Thanks,
Lee
2 Suggested Answers
jell587
  • 447 Answers
SOURCE: after upgrading RAM 1G to 1.5G
You should be good to go, if you had the wrong memory mod the machine would probably just blink or beep at you. If you experience blue screen errors or virtual memory errors this could be a sign of incompatibility but I would say you're probably fine.
Ram isssue
Part Number: AspireOneAOA150 Aspire One AOA150
RAM / Max RAM 512 MB onboard DDR2 533 MHz SDRAM single channel with onboard SDRAM and one soDIMM slot, with up to 1 GB/1.5 GB using one 512 MB/1 GB soDIMM module
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Sep 06, 2012 | Acer Computers & Internet
I tried to upgrade my acer aspire one A150 to a 2 GB stick of ram - didn't work so reinstalled the 512 stick I had (SHOULD be a total of 1 mb counting the 512 onboard.) It is NOW only recognizing 512. ...
Try swapping the ram sticks with each other and see if it still reports 512. If it does...then it sounds like you damaged one of the seats for the RAM somehow. Did you have any static shocks occur?
Mar 02, 2011 | Acer Computers & Internet
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
How do I install a 1g ram into an acer aspire 3690 laptop
under on bothem are one bank for ram and the other are undr keyboard remove on knikking point plastic above keyboard carfully and release two /tree srews and keybord can be removed replace ram and do revers for montage
Dec 31, 2009 | Acer Aspire 3690 Notebook
Acer Aspire One AOA 105-1049 Would like to upgrade memory. What do I need.
your laptop comes with 1g of (DDR2 SDRAM)
( DDR2 SDRAM - 533 MHz SO DIMM 200-pin)
so you will need any
DDR2 SDRAM - 533 MHz SO DIMM 200-pin ram.
the pin is very important. and it has to be notebook ram.
how ever the bad news is your laptop bored will only support going up to 1.5g
so sticking a 512mb in your gona lose part of it, as well you take the chance of making your system unstable. Below is a link of what your looking for.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=DDR2+SDRAM+-+533+MHz+SO+DIMM+200-pin%29&x=10&y=29
for the added performance on updating your ram your not going to get your money worth. I just recommend saving your money.
please rate this and mark it fixya if it has helped.
Nov 27, 2009 | Acer Aspire One A150-1049 Notebook
After upgrading RAM 1G to 1.5G
The BIOS will recognize the new ram when the pc is turned on. If the amount is being reported correctly and there are no beeps you are good to go.
Feb 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire 3690 2970
Crucial's website says your computer will hold up to 2GB max. There are 2 slots. Also says you can mix sizes.
Here is their link for additional info.
Acre Aspire 3690 Series Memory
You can also do a scan on the site and they will make reccommendations for you.
Nov 03, 2008 | Acer Aspire 3690-2196 Notebook
Memory issues acer t180 ud360a, no boot up with all (4) ram slots filled...
i had same problem with mine, i have the acer aspire ast180-ud360a, dont put the same memory next to each other, u have to stagger it, so it looks like
------------> [1gb] [512mb] [1gb] [512mb] <--- correct setup
and not like
------------> [1gb][1gb][512mb][512mb] <--- incorrect setup
Nov 25, 2007 | Acer Aspire™ T180 PC Desktop
RAM ON acer computers
Yes... just need to purchase the right stuff.
You need to determine if you have DDR or DDRII. And then determine if you have one stick of 512, or if you have 2 sticks of 256. Once you know this information, visit your local Best Buy or purchase somewhere online, a memory upgrade. Such as 2 sticks at 512mb for 1 gig total. Assuming you have two memory slots, should have anyway.
DDRII is fairly cheap right now, be a good time to upgrade. DDR on the other hand, is still a little more expensive.
Oct 30, 2007 | Acer Aspire 3680 Laptop
Acer Aspire One Netbook 8.9" Notebook Logo
470 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
