WHEN THE clocks MINIUTE HAND IS DIRECTLY ON THE 12 THE HOUR HAND DOES NOT ALIGN TO THE HOUR. FOR EXAMPLE IF ITS 3 O'CLOCK THEN THE HOUR HAND SHOULD BE DIRECTLY ON THE 3 BUTS ITS IS SLIGHTLY BELOW THE 3
Unfortunately the only way I know of synchronizing the hands is to remove the glass. I am assuming your clock has a plastic glass which is held in by 3 knibs which protrude into the case.
Examine the edge of the glass and locate one of the knibs, with a small screwdriver gently but firmly push this knib in and pull the glass up to release it. Once out you can position all the hands at exactly 12 o'clock by pushing them gently (don't take them off). Replace the glass and your done!
www.serendipity-gifts.co.uk)
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
SOURCE: how to reset la crosse wall clock
It sets itself. You choose the time zone.
watch the video.
http://www.klockit.com/products/dept-52__sku-87109.html
Downoad a typical manual.
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
SOURCE: I have a La Crosse wall clock, model WT-3102. It
Sounds like it is not picking up the radio signal.
--- Please dont forget to vote this answer was helpful. Many thanks ------
Try placing it in a window overnight where the radio signals do not get obstructed.
I'd say you have a lemon.
Manual:
For warranty work, technical support, or information contact:
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail
(warranty work)
(information on other products)
Website
http://www.lacrossetechnology.com/
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
