Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Have to restart my furance all the the time...
I have a burnham gas furnace. It is about 7 years old. After so many cycles it doesn't want to start back up again. If I take off the front panel cover, there is a little box on the upper left corner that looks like it supplies the power? if i tap it or when it gets jarred by the door being opened and closed, the furance will start back up. any idea what that 'hangy thing' is? is it the electronic ignition? I have a service contract with my gas company but i'm not covered for the ignition. If that is what this part is, I can call and add it on before my service call and I'll be covered for the part.
  • deeceedee Feb 26, 2009
    oops i posted this in the wrong category! sorry!
    New Friend:
  • 92 Answers
The little box is a isolation relay if it is brown and black and it sounds like a lose connection
Posted on Feb 26, 2009
My goodman furance runs on full cycle then it won't start again til i turn power off then back on
May be a stuck relay on the circuit board. The only other thing I can think of would be a thermostat having intermittent problems.
Feb 28, 2015 | Goodman Manufacturing Goodman GMS81005CN...
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Ruud 90+ Model UGRA 10EZAJS Trips Out
Check for condensation buildup in the Induction Blower housing. The condensate tubes or canister may be blocked and causing the diaphragm switch to trip the unit out causing the burners to shut down.
Feb 11, 2012 | Ruud Heating & Cooling
Can you tell me the order in which each componet of a gas furnace comes on to start the furance?
Yes there is a sequence:
0:00 Dial for fan/limit switch is at 70 deg position. Furnace is cold. I turn T-stat to 80 deg to start furnace.
1:00 Burner comes on and dial begins to move slowly up.
2:30 Dial at 140 deg and fan motor comes on. Dial never goes above 150 deg.
3:00 Burner turns off. Dial slowly moves back towards 90 deg.
4:45 Burner turns on and dial is at 110 deg.
4:50 Fan turns off with dial still at 110 deg.
5:30 Burner off. Dial at 120 deg.
6:15 Fan on. Dial at 140 deg. Burner is still off.
7:00 Burner on. Dial at 120 deg.
7:40 Burner off. Dial still at 120 deg.
8:30 Fan off with dial at 110 deg., and it quickly snaps back to the 80 deg. position.
8:30 plus, cycle continues.....
Mar 25, 2010 | Heating & Cooling
I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Lenox Gas Furance Summer Fan Not Working
Just curious, there sometimes is a safety switch on the door to the fan unit so no one gets hurt opening it to change filters ...etc... make sure all the doors are on tightly
Jul 30, 2009 | Dryers
Knock Noise When Carrier Furance Starts Up
have the ac company check the actual blower wheel itself it may be slowly coming apart
Apr 20, 2009 | Carrier Heating & Cooling
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Ruud heater will not light consistently
Your furnace is going into a lockout condition, cycling the power resets the circuit board and it starts over. I will need to know approximate age and model of your furnace, it sounds like you have need to clean the flame sensor rod. However i need to know what i am working with.
Dec 18, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
